OpenFOAM_FOAM FATAL ERROR
Old   June 23, 2021, 21:31
Default OpenFOAM_FOAM FATAL ERROR
A
David Jean is on a distinguished road
Hi guy,
I am running radiation heat transfer in buildings with solver "buoyantSimpleFoam". But I meet this problem."FOAM FATAL ERROR:
Maximum number of iterations exceeded: 100"
(I have attached the picture)
Could I ask you a question? how to handle this issue?
Thank you in advance.
I hope you are doing well
David Jean is offline   Reply With Quote
Old   June 24, 2021, 01:36
piu58's Avatar
Uwe Pilz
piu58 is on a distinguished road
You should check your temperature connected boundary conditions. Other reasons my be awkward initialization for T. Do you have any heat sources? Look at them, if they go to very high values.
Uwe Pilz
Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950)
piu58 is offline   Reply With Quote
Old   June 24, 2021, 04:27
A
Hi Sir,
Thank you so much for your support
[OpenFOAM] ParaView command in Foam-extend-4.1 mitu_94 ParaView 0 March 4, 2021 14:46
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries NickG OpenFOAM Installation 3 December 30, 2019 01:21
Errors in UDF shashank312 Fluent UDF and Scheme Programming 6 May 30, 2013 21:30
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 21:50
user subroutine error CFDUSER CFX 2 December 9, 2006 07:31
