Dakota parallel
Old   June 23, 2021, 05:39
Default Dakota parallel
Johnny Mercurial
JohnnyMercu is on a distinguished road
Hi everyone,
I hope my post won't be off topic, here is my question :
I aml currently using Dakota 6.13 with OpenFoam 2012 in order to optimize parameters, and I am trying to build a surrogate-based optimization. The thing is I want to run several OpenFOAM in parallel to reduce the calculation time. Does anyone have already done something similar ? The OpenFOAM simulation I use runs on 6 processors and here is my dakota input file :
environment
 tabular_data
method
 id_method = 'SBGO'
 surrogate_based_global
   model_pointer = 'SURROGATE'
   method_pointer = 'SOGA'
   max_iterations = 15
   replace_points
 output verbose
method
 id_method = 'SOGA'
 soga
    seed = 10983
  max_function_evaluations = 30000
  #initialization_type unique_random
 output silent
model
 id_model = 'SURROGATE'
 surrogate global
    dace_method_pointer = 'SAMPLING'
    #correction additive zeroth_order
    gaussian_process dakota
method
 id_method = 'SAMPLING'
 sampling
   samples = 50
   seed 531
   sample_type lhs
   model_pointer = 'TRUTH'
model
 id_model = 'TRUTH'
 single
   interface_pointer = 'TRUE_FN'
variables
  active uncertain
  uniform_uncertain 4
   descriptors     'came_start' 'stiffness1'  'stiffness2' 'stiffness3'
   lower_bounds           -210          200           1200         2600
   upper_bounds           -150          400           1600         3000
interface
 id_interface = 'TRUE_FN'
 analysis_drivers = 'dakota3.sh'
   fork
    work_directory named 'workdir/run'
    directory_tag directory_save
    parameters_file 'params.in'
    results_file 'results.out'
    link_files 'dakotaParameter.orig' 'transfert.py' 'ecriture_xml_v3.py'
responses
  objective_functions=1
   descriptors 'res'
   no_gradients
   no_hessians
   sense 'max'
Best regards,
Johnny
JohnnyMercu is offline   Reply With Quote
dakota, parallel
Error running openfoam in parallel fede32 OpenFOAM Programming & Development 5 October 4, 2018 17:38
Explicitly filtered LES saeedi Main CFD Forum 16 October 14, 2015 12:58
simpleFoam parallel AndrewMortimer OpenFOAM Running, Solving & CFD 12 August 7, 2015 19:45
simpleFoam in parallel issue plucas OpenFOAM Running, Solving & CFD 3 July 17, 2013 12:30
parallel Grief: BoundaryFields ok in single CPU but NOT in Parallel JR22 OpenFOAM Running, Solving & CFD 2 April 19, 2013 17:49
