polyMesh directory files contain special characters
Old   June 11, 2021, 18:34
Default polyMesh directory files contain special characters
Vinith Mohan
vinithm is on a distinguished road
Hello everyone,
I'm new to OpenFOAM. Lately I have been trying to run the motorBike tutorial. When I execute the surfaceFeatureExtract command, the resulting polyMesh directory files except the 'boundary' file contains special characters. I have attached the file for reference. Any help is greatly appreciated.
Thank you all.
vinithm is offline   Reply With Quote
Old   June 12, 2021, 14:01
Tobermory will become famous soon enough
Check your controlDict, and in particular the writeFormat parameter. It's probably binary, in which case change it to ascii and the file contents will all be plain text ... but much larger of course.
Tobermory is offline   Reply With Quote
Old   June 12, 2021, 15:08
Vinith Mohan
Thank you for the reply Tobermory, I was able to fix the problem.
I also have an additional question. When 'simpleFoam' is executed, I can see from the log file 'no convergence criteria found', 'no MRF models present' , 'no finite volume options present'. In addition, I find two warnings:
1. FOAM Warning :
From Foam::labelHashSet Foam:olyBoundaryMesh:atchSet(const Foam::UList<Foam::wordRe>&, bool, bool) const
in file meshes/polyMesh/polyBoundaryMesh/polyBoundaryMesh.C at line 896
Cannot find any patch or group names matching motorBikeGroup
forceCoeffs forceCoeffs1:
2. --> FOAM Warning :
In the end, flow fields have not been calculated. I have not made any changes to the tutorial files. I have attached the log file.
Could you please tell me where am I going wrong?
Thanks.
Old   June 13, 2021, 12:20
The three warnings:
are as expected and normal - these are just informing you that no convergence criteria are set in fvSolution (you can, and should, use these criteria to stop simulations when they are sufficiently converged ... not necessary for this tutorial case though), that the case does not involve moving meshes and that there are no fvOptions additions.
The next two warnings are fatal - I would check the output of the log files from the previous steps in the Allrun - something has clearly gone wrong with the meshing. Good luck.
Old   June 13, 2021, 13:08
Vinith Mohan
Thank you Tobermory. I think I have understood where I have gone wrong and will fix it based on the hints given by you.
thanks again.
[waves2Foam] Waves2Foam Related Topics ngj OpenFOAM Community Contributions 660 August 20, 2018 13:39
OpenFoam "Permission denied" and "command not found" problems. iyidaniel@yahoo.co.uk OpenFOAM Running, Solving & CFD 11 January 2, 2018 07:47
polynomial BC srv537 OpenFOAM Pre-Processing 4 December 3, 2016 10:07
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 20:43
Re : Problem Installing OpenFOAM on Centos -5.3 mohanphy OpenFOAM Installation 1 February 7, 2010 20:09
