p_rgh diverges and is calculated multiple times? |
June 8, 2021, 07:10 |
Claudia
Rep Power: 5 |
Hey guys!
I am trying to simulate an air flow around a Geometry. I have attached a foto of the geometry as well as a close up of the mesh. I need to use chtMultiRegion because later on I will study the heat transfer. Right now i am using k-epsilon turbulence and steadyState. The objective is to use this solution as a start for a transient simulation with heat exchange. Problem: My solution does not converge, especially p_rgh. I tried playing around with the mesh, the relaxation factor, the nonOrthogonalCorrectors... but everything is just making it worse. Question: 1. Is it a problem with my mesh? I have some non-orthogonal an skew faces. 2. How can I improve my simulation? 3. In my log file you can see that OF calculates p_rgh multiple times during 1 timestep. Is that an error? the fvSolution file for the air: Code:
FoamFile { version 2.0; format ascii; class dictionary; location "system/Luft"; object fvSolution; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // solvers { "h.*" { solver PBiCGStab; preconditioner DILU; tolerance 1e-7; relTol 1e-7; minIter 5; maxIter 50; } "hFinal.*" { $h; } "e.*" { $h; } "eFinal.*" { $h; } rho { solver GAMG; smoother GaussSeidel; tolerance 0.0001; relTol 0.0001; // maxIter 10; } rhoFinal { $rho; relTol 0; // maxIter 20; } p_rgh { solver GAMG; smoother GaussSeidel; tolerance 0.0001; relTol 0.0001; maxIter 20; } p_rghFinal { $p_rgh; tolerance 0.0001; relTol 0.0001; } "(U|k|epsilon|omega|R).*" { solver PBiCGStab; preconditioner DILU; tolerance 0.0001; relTol 0.0001; } "(U|k|epsilon|omega|R)Final.*" { $U; tolerance 0.0001; relTol 0; // maxIter 20; } } PIMPLE { momentumPredictor yes; nOuterCorrectors 1; nCorrectors 2; nNonOrthogonalCorrectors 0;//1 leads to extreme fluctuation of p_rgh; outerCorrectorResidualControl { "(U|k|epsilon|omega|p_rgh).*" { tolerance 1e-4; relTol 0; } "h.*" { tolerance 1e-7; relTol 0; } "e.*" { tolerance 1e-7; relTol 0; } } } relaxationFactors { fields { p_rgh 1; p_rghFinal 1; rho 1; rhoFinal 1; } equations { h 0.001; e 0.001; hFinal 0.001; eFinal 0.001; U 0.1; UFinal 0.1; k 0.1; omega 0.1; epsilon 0.1; kFinal 0.1; epsilonFinal 0.1; omegaFinal 0.1; } } Code:
FoamFile { version 2.0; format ascii; class dictionary; location "system/Luft"; object fvSchemes; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // ddtSchemes { default steadyState;//CrankNicolson 0.9; } gradSchemes { default Gauss linear; } divSchemes { default none; div(phi,U) bounded Gauss upwind; //bounded weg für transient? div(phi,K) bounded Gauss upwind;; div(phi,h) bounded Gauss upwind; div(phi,e) bounded Gauss upwind; div(phi,k) bounded Gauss upwind; div(phi,epsilon) bounded Gauss upwind; div(phi,omega) bounded Gauss upwind; div(phi,R) bounded Gauss upwind; div(phi,K) bounded Gauss linear; div(phi,Ekp) bounded Gauss linear; div(R) Gauss linear; div(U) Gauss linear; div(((rho*nuEff)*dev2(T(grad(U))))) Gauss linear; } laplacianSchemes { default Gauss linear uncorrected; } interpolationSchemes { default linear; } snGradSchemes { default corrected; } wallDist { method meshWave; } Can someone give me advice? |
July 7, 2021, 02:39 |
Hosam Alrefaie
Rep Power: 5 |
I have the same problem with p_rgh, it has high residuals and too many iterations each time.
I am using fixedFluxPressure BC for the inner pipe walls. |
July 7, 2021, 03:13 |
Uwe Pilz
Rep Power: 15 |
I recommend using relaxationFactors in fvSolution. You should at least some kind of result then.
I don't like your mesh, I found the steps of refinement to steep. May be a coarser mesh is at least a better starting point. But this is hard to say without a result. I recommend simplifying your geometry and investigating the "bump" and the "pits" isolated, at least at the beginning.
Uwe Pilz -- Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950) |
chtmultiregion, chtmultiregionfoam, p_rgh devergence |
