twoLiquidMixingFoam stopping before specified endTime
Old   June 6, 2021, 16:23
Default twoLiquidMixingFoam stopping before specified endTime
Pierre-Olivier Schwarz
PoSchwarz is on a distinguished road
Hi!
I'm new to OpenFoam and I'm trying to simulate the mixing of two fluids in a cross junction of two pipes. I'm using twoLiquidMixingFoam, but I first set the velocity field using potentialFoam to avoid errors.
I attached the files I use. I first have to run potentialFoam (setUField folder), then copy the U file in the 0 folder of the twoLiquidMixingFoam folder.
However, when I launch the simulation with twoLiquidMixingFoam, the simulation always stops to early, before the mixing even begins to occur. I tried to change the tolerance, the time precision and the endTime, but none of this seems to change anything.
I get really high velocities, pressures and epsilon values at certain points in the junction at the last time step that is executed. Maybe the problem comes from these values? In that case, what should I do to correct them?
Thank you very much!
Pierre-Olivier
PoSchwarz is offline   Reply With Quote
cross junction, endtime, twoliquidmixingfoam
PIMPLE at twoLiquidMixingFoam - p_rgh divergence - slow solving pconen OpenFOAM Running, Solving & CFD 13 August 19, 2019 04:16
cannot set exact 'endtime' in controlDict when using a steady state solver minecraftgp OpenFOAM Running, Solving & CFD 4 July 24, 2018 06:13
Stopping criterion for outer iteration loop luftraudi Main CFD Forum 3 February 22, 2017 09:59
simpleFoam stopping before specified endtime ss32 OpenFOAM Running, Solving & CFD 3 April 12, 2016 12:05
Asymptotic stopping criterion is not working rob50904 STAR-CCM+ 2 January 28, 2013 09:25
