Parallelization of multi-region mesh
Old   June 3, 2021, 19:08
Default Parallelization of multi-region mesh
Jan995 is on a distinguished road
Hi all,
I have a problem with decomposition or in fact, running the multi-region mesh with different decomposition values. For example, I have a huge fluid region - more than 100mio cells and small solid region (around 1mio cells). I decompose the fluid region to few thousand processors, but only decompose the solid region to around 100 processors.
Now, the problem is, that when doing that I obtain an error when running chtMultiRegionFoam that in the processor* folders there are no points for solid region. There are no points for some processors for solid region as I have decomposed it into fewer processors. Do I need to do another step when doing the decomposition? Decomposition of the solid region into several thousand processors is really not optimal and I would like to run with different decompositions for different regions. Is there a way?
Jan995 is offline   Reply With Quote
Old   June 7, 2021, 11:31
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
You can specify in the decomposeParDict to keep face regions. Never checked it out but it should be possible. https://github.com/OpenFOAM/OpenFOAM...composeParDict
However, mixing different numbers of processors does not work (I never heard that). Nevertheless, FOAM is decomposing in a way that each processor does have (more or less) the same amount of cells (e.g., using scotch decomposition method).
Keep foaming,
Tobias Holzmann
Tobi is offline   Reply With Quote
[snappyHexMesh] snappyHexMesh stuck when snap is turned on yukuns OpenFOAM Meshing & Mesh Conversion 3 February 2, 2021 14:05
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 06:38
Problem with chtMultiregionFoam radiation boundary condition baran_foam OpenFOAM Running, Solving & CFD 10 December 17, 2019 18:36
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 04:52
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 10:38
