Correct BCs for known outlet conditions and unknown inlet conditions
Old   June 17, 2021, 03:56
Daniel
DevilX is on a distinguished road
This is really strange to be honest. Then there is a problem with BC´s oder Solver for sure (guessing gives the BC´s a bigger impact).
DevilX is offline   Reply With Quote
Old   December 7, 2024, 16:09
Guilherme
gdnascimento is on a distinguished road
Hi Lewis,
I was trying to set up a pressure-driven flow in a atomization nozzle and faced a similar problem as yours. The thing that worked for my application was using a condition based on the solution proposed by Daniel, changing 'totalPressure' for 'uniformTotalPressure', where I could use a table to gradually increase p0 values and contour rhoSimpleFoam hyper-sensibility.
Hope you have found a solution earlier, but if not, check if this adaption is usefull to your case.
Best regards.
gdnascimento is offline   Reply With Quote
Old   December 20, 2024, 09:14
Suhan Umur Okuducu
suoCFD is on a distinguished road
Did you use this BC for inlet and outlet Temperature. Do not forget to change inletValue and value for your case.
patch
type inletOutlet;
inletValue uniform 300;
value uniform 300;
suoCFD is offline   Reply With Quote
openfoam 7, rhosimplefoam
dsmcInitialise - dsmcFoam archymedes OpenFOAM Pre-Processing 94 July 15, 2016 17:14
pressure inlet conditions for unknown pressure dEntropy OpenFOAM Pre-Processing 5 July 15, 2015 17:27
mass flow and pressure BC known at inlet, outlet BCs unknown akashmpatil FLUENT 1 December 12, 2013 14:02
[OpenFOAM] Saving ParaFoam views and case sail ParaView 9 November 25, 2011 16:46
compressible two phase flow in CFX4.4 youngan CFX 0 July 2, 2003 00:32
