pimpleFoam - displacementLaplacian: Cells stretch & overlap near body after rotation |
May 31, 2021, 05:17 |
Julian
Rep Power: 5 |
Hi everyone,
I am simulating a rotational movement of an airfoil with pimpleFoam & displacementLaplacian. After 558 of 1000 time steps, the simulation crashes due to an overlap of cells at the bottom: I have already tried several things such as changing the cell diffusivity from Code:
displacementLaplacianCoeffs { diffusivity uniform; } Code:
displacementLaplacianCoeffs { diffusivity exponential 0.01 inverseDistance ("airfoil.*"); } Code:
deltaT 0.01; Code:
deltaT 0.001; Now I am asking, which parameters I could change in addition to avoid this cell overlap / collision. You can find further videos of the mesh movement here: airfoil bottom airfoil top airfoil In addition I have attatched the files of the case here. (It is a coupled simulation with the coupling library preCICE, which couples OpenFOAM to MBDyn. Therefore you cannot run pimpleFoam without preCICE and MBDyn installed, but you can look at the files in the fluid folder.) |
September 12, 2024, 06:05 |
Alice Zanella
Rep Power: 7 |
Did you manage to solve your problem? Because I have literally the same problem and I'm stuck.
solid body rotation of grid | Duncan_vdH | OpenFOAM Running, Solving & CFD | 2 | March 22, 2017 15:03 |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 09:54 |
WILLING TO PAY/ FREELANCER REQUIRED / small UDF coding force loads over body / 6DOF | acasas | CFD Freelancers | 1 | January 23, 2015 08:26 |
[Netgen] Import netgen mesh to OpenFOAM | hsieh | OpenFOAM Meshing & Mesh Conversion | 32 | September 13, 2011 06:50 |
physical boundary error!! | kris | Siemens | 2 | August 3, 2005 01:32 |
