chtMultiRegionSimpleFoam negative temperature error
Old   May 30, 2021, 10:33
Default chtMultiRegionSimpleFoam negative temperature error
mirmiyo is on a distinguished road
In my model basically I have a fin which is cooled by water flow. Could you help me identify the problem?
I'm getting following error:
"Solving for fluid region fluid
DILUPBiCGStab: Solving for Ux, Initial residual = 0.82521303, Final residual = 0.051942511, No Iterations 3
DILUPBiCGStab: Solving for Uy, Initial residual = 0.87814371, Final residual = 0.075666319, No Iterations 3
DILUPBiCGStab: Solving for Uz, Initial residual = 0.75621016, Final residual = 0.054092061, No Iterations 11
DILUPBiCGStab: Solving for h, Initial residual = 0.81033778, Final residual = 0.078598853, No Iterations 12
--> FOAM FATAL ERROR: (openfoam-2012)
Negative initial temperature T0: -29.402764"
My boundary conditions are:
(U)
outlet
type pressureInletOutletVelocity;
value $internalField;
inlet
type flowRateInletVelocity;
massFlowRate 0.4;
extrapolateProfile yes;
(p_rgh)
internalField uniform 1e5;
boundaryField
#includeEtc "caseDicts/setConstraintTypes"
type fixedFluxPressure;
outlet
type fixedValue;
(T)
boundaryField
inlet
type fixedValue;
topWall
type zeroGradient;
outlet
type inletOutlet;
inletValue $internalField;
leftWall
type symmetryPlane;
rightWall
type symmetryPlane;
fluid_to_heatSink
type compressible::turbulentTemperatureCoupledBaffleMix ed;
Tnbr T;
kappaMethod fluidThermo;
mirmiyo is offline   Reply With Quote
Old   May 31, 2021, 16:47
Post
cal
saidc. is on a distinguished road
Hi mirmiyo,
In my experience this error is usually caused by bad mesh. If you share your checkMesh results, you can find help easier. Also you should check your schemes too. You can try limit temperature.
Please check these posts.
chtMultiRegionFoam natural convection negative initial temperature
Kind Regards,
Said.
saidc. is offline   Reply With Quote
[OpenFOAM] ParaView command in Foam-extend-4.1 mitu_94 ParaView 0 March 4, 2021 14:46
error compiling modified applications yvyan OpenFOAM Programming & Development 21 March 1, 2016 05:53
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 19:00
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 10:31
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
