May 30, 2021, 10:18 |
Help with cyclic boundary condition needed
Claudia
Rep Power: 5 |
Hey guys!
as you can see in the attached snapshots, i have have a tray filled with Schokolate inside a windtunnel. In the real windtunnel, there are 3 of these trays on top of each other. So basically where the upper and lower wall is, would actually start another tray. I want to use the cyclic boundary condition, but i have some problems with it. I tried changing the boundary file but I am confused about some entries, for example the "separation vektor" and the "matchTolerance" one. My boundaryFile looks like this: Code:
7 ( inlet { type patch; nFaces 1350; startFace 2606557; } outlet { type patch; nFaces 1350; startFace 2607907; } walls { type wall; inGroups List<word> 1(wall); nFaces 23802; startFace 2609257; } upperWall { type cyclic; inGroups List<word> 1(cyclic); nFaces 9000; startFace 2633059; matchTolerance 0.001; //? transform translational; neighbourPatch lowerForm; separationVector (0 0 0); //? } wallsForm { type wall; inGroups List<word> 1(wall); nFaces 53516; startFace 2642059; } lowerForm { type cyclic; inGroups List<word> 1(cyclic); nFaces 60900; startFace 2695575; matchTolerance 0.001; transform translational; neighbourPatch upperWall; separationVector (0 0 0); } Schokolade { type wall; inGroups List<word> 1(wall); nFaces 38520; startFace 2756475; } ) |
boundary condition, cyclic, cyclic bc |
Cyclic boundary condition on SALOME mesh | kandelabr | OpenFOAM Pre-Processing | 17 | March 8, 2024 05:14 |
Mixing cyclic and wall boundary condition | al_th | OpenFOAM Pre-Processing | 6 | September 20, 2019 05:06 |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 08:30 |
Question about adaptive timestepping | Guille1811 | CFX | 25 | November 12, 2017 18:38 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 07:20 |
