Foam-Extend 4.1 Mpi doesn't exit gracefully at the end of parallel run |
May 30, 2021, 03:04 |
Sultan Islam
Rep Power: 10 |
I keep getting this error at the end of parallel run of motorbike tutorial (incompressible/simpleFoam/motorBike)
Time = 500 smoothSolver: Solving for Ux, Initial residual = 0.0006944024657, Final residual = 3.53775822e-05, No Iterations 4 smoothSolver: Solving for Uy, Initial residual = 0.01562265045, Final residual = 0.0007816664689, No Iterations 4 smoothSolver: Solving for Uz, Initial residual = 0.01689126298, Final residual = 0.0007994511231, No Iterations 4 GAMG: Solving for p, Initial residual = 0.0516009244, Final residual = 0.001785455829, No Iterations 2 GAMG: Solving for p, Initial residual = 0.006455040592, Final residual = 0.0002815610234, No Iterations 2 GAMG: Solving for p, Initial residual = 0.001025026437, Final residual = 5.392941651e-05, No Iterations 2 time step continuity errors : sum local = 8.503000961e-06, global = 2.788574767e-07, cumulative = 4.251833852e-05 smoothSolver: Solving for omega, Initial residual = 0.0002316681103, Final residual = 1.624408098e-05, No Iterations 3 smoothSolver: Solving for k, Initial residual = 0.002295694433, Final residual = 0.000177742857, No Iterations 3 [eXohost:232610] *** Process received signal *** [eXohost:232610] Signal: Segmentation fault (11) [eXohost:232610] Signal code: (-6) [eXohost:232610] Failing at address: 0x3e800038ca2 [eXohost:232609] *** Process received signal *** [eXohost:232609] Signal: Segmentation fault (11) [eXohost:232609] Signal code: (-6) [eXohost:232609] Failing at address: 0x3e800038ca1 [eXohost:232607] *** Process received signal *** [eXohost:232607] Signal: Segmentation fault (11) [eXohost:232607] Signal code: (-6) [eXohost:232607] Failing at address: 0x3e800038c9f [eXohost:232608] *** Process received signal *** [eXohost:232608] Signal: Segmentation fault (11) [eXohost:232608] Signal code: (-6) [eXohost:232608] Failing at address: 0x3e800038ca0 [eXohost:232606] *** Process received signal *** [eXohost:232606] Signal: Segmentation fault (11) [eXohost:232606] Signal code: (-6) [eXohost:232606] Failing at address: 0x3e800038c9e ExecutionTime = 230.86 s ClockTime = 233 s End [eXohost:232605] *** Process received signal *** [eXohost:232605] Signal: Segmentation fault (11) [eXohost:232605] Signal code: (-6) [eXohost:232605] Failing at address: 0x3e800038c9d -------------------------------------------------------------------------- mpirun noticed that process rank 4 with PID 232609 on node eXohost exited on signal 11 (Segmentation fault). -------------------------------------------------------------------------- Interestingly enough, the case does complete solving and reconstructs well. All solution is accessible in paraview. Anyone else have this issue? It seems that mpirun doesn't like how it exits at the end of parallel run for GAMG. I am using the master branch of foam-extend-4.1 and using Third Party OpenMPI. Seems like there is always some non fatal bug with every foam extend release, otherwise everything works, even solids4foam works. |
Centrifugal fan-reverse flow in outlet lesds to a mass in flow field | xiexing | CFX | 3 | March 29, 2017 10:00 |
Difficulty in calculating angular velocity of Savonius turbine simulation | alfaruk | CFX | 14 | March 17, 2017 06:08 |
Ansys CFX problem: unexpected very high temperatures in premix laminar combustion | faizan_habib7 | CFX | 4 | February 1, 2016 17:00 |
Low torque values on Screw Turbine | Shaun Waters | CFX | 34 | July 23, 2015 08:16 |
Low Mixing time Problem | Mavier | CFX | 5 | April 29, 2013 00:00 |
