May 28, 2021, 07:24 |
Problem with parallel run
I'm having some problems when trying to run the tutorial case damBreak in parallel. It used to work some time ago, but now I get the following error in the terminal:
*** An error occurred in MPI_Init_thread *** on a NULL communicator *** MPI_ERRORS_ARE_FATAL (processes in this communicator will now abort, *** and potentially your MPI job) [tokio:2902664] Local abort before MPI_INIT completed completed successfully, but am not able to aggregate error messages, and not able to guarantee that all other processes were killed! *** An error occurred in MPI_Init_thread *** on a NULL communicator *** MPI_ERRORS_ARE_FATAL (processes in this communicator will now abort, *** and potentially your MPI job) [tokio:2902663] Local abort before MPI_INIT completed completed successfully, but am not able to aggregate error messages, and not able to guarantee that all other processes were killed! -------------------------------------------------------------------------- Primary job terminated normally, but 1 process returned a non-zero exit code. Per user-direction, the job has been aborted. -------------------------------------------------------------------------- -------------------------------------------------------------------------- mpirun detected that one or more processes exited with non-zero status, thus causing the job to be terminated. The first process to do so was: Process name: [[10459,1],0] Exit code: 1 Thanks in advance |
solids4foam FSI overset parallel run problem | jenksson | OpenFOAM Running, Solving & CFD | 2 | October 17, 2022 16:27 |
OpenFOAM Parallel Run Problem | javier2098 | OpenFOAM Pre-Processing | 1 | November 27, 2019 01:01 |
Problem in foam-extend 4.0 ggi parallel run | Metikurke | OpenFOAM Running, Solving & CFD | 0 | February 20, 2018 07:34 |
nonNewtonianIcoFoam - problem with parallel run | chris_sev | OpenFOAM Bugs | 4 | April 1, 2009 10:13 |
Problem on Parallel Run Setup | Hamidur Rahman | CFX | 0 | September 23, 2007 18:11 |
