epsiloncodedSource: 'error: could not load dynamicCode' |
May 27, 2021, 15:51 |
Kabir Shariff
Rep Power: 10 |
Hello Foamers,
I want to add a source term in the k-epsilon (see attachment) model in a defined region. I want to use the coded source to write my expression and solve the equation. I am having an error when running the simulation, it crashes on 1st iteration. Here is my code in fvOptions. (I try to add epsilon only first to make sure the code id OK, later on, I will include the k-source) Code:
epsilonSource { type scalarCodedSource; selectionMode cellSet; cellSet actuationDisk1; fields (epsilon); name epsilonSource; codeInclude #{ #include "OFstream.H" #}; codeAddSup #{ const Time& time = mesh().time(); //declare constants const scalar Ce_ = 1.92; const scalar epAmb_ = 1.61e-3; const scalar kAmb_ = 4.57e-3; // define mesh const vectorField& CellC = mesh_.C(); // declare source scalarField& epsilonSource = eqn.source(); // Apply the source forAll(cellC, i) { // epsilon source epsilonSource[i] += rho()*Ce_*sqr(epAmb_)/kAmb_; std::ofstream file; file.open ("Epsilonterm.txt", std::ofstream::out | std::ofstream::app); file << time.value() << " " << epsilonSource[i] << " " << CellC[i].y() << std::endl << "\n"; file.close(); }; #}; codeCorrect #{ #}; codeConstrain #{ #}; } Code:
Selecting finite volume options type scalarCodedSource Source: epsilonSource - selecting cells using cellSet actuationDisk1 - selected 1968 cell(s) with volume 0.00115206175747 Time = 1 smoothSolver: Solving for Ux, Initial residual = 1, Final residual = 0.0847902582144, No Iterations 1 smoothSolver: Solving for Uy, Initial residual = 0.999826124119, Final residual = 0.0478604369223, No Iterations 1 smoothSolver: Solving for Uz, Initial residual = 1, Final residual = 0.0284598334923, No Iterations 3 GAMG: Solving for p, Initial residual = 1, Final residual = 0.000848836521673, No Iterations 17 time step continuity errors : sum local = 3.2538733323e-05, global = -9.57013476506e-07, cumulative = -9.57013476506e-07 Could not load "/dlocal/run/8251943/dynamicCode/platforms/linux64GccDPInt32Opt/lib/libepsilonSource_868e6b493283f3b08eed87e0a7187b68c731d1e4.so" /dlocal/run/8251943/dynamicCode/platforms/linux64GccDPInt32Opt/lib/libepsilonSource_868e6b493283f3b08eed87e0a7187b68c731d1e4.so: cannot open shared object file: No such file or directory Using dynamicCode for fvOption::epsilonSource at line 39 in "/dlocal/run/8251943/constant/fvOptions.epsilonSource" Invoking wmake libso /dlocal/run/8251943/dynamicCode/epsilonSource /dlocal/run/8251943/dynamicCode/platforms/linux64GccDPInt32Opt/lib/libepsilonSource_868e6b493283f3b08eed87e0a7187b68c731d1e4.so: cannot open shared object file: No such file or directory /dlocal/run/8251943/dynamicCode/platforms/linux64GccDPInt32Opt/lib/libepsilonSource_868e6b493283f3b08eed87e0a7187b68c731d1e4.so: cannot open shared object file: No such file or directory wmake libso /dlocal/run/8251943/dynamicCode/epsilonSource ln: ./lnInclude dep: codedFvOptionTemplate.C Ctoo: codedFvOptionTemplate.C In file included from /soft/OpenFOAM-v2006/OpenFOAM-v2006/src/OpenFOAM/lnInclude/keyType.H:46:0, from /soft/OpenFOAM-v2006/OpenFOAM-v2006/src/OpenFOAM/lnInclude/Ostream.H:43, from /soft/OpenFOAM-v2006/OpenFOAM-v2006/src/OpenFOAM/lnInclude/OSstream.H:42, from /soft/OpenFOAM-v2006/OpenFOAM-v2006/src/OpenFOAM/lnInclude/messageStream.H:255, from /soft/OpenFOAM-v2006/OpenFOAM-v2006/src/OpenFOAM/lnInclude/error.H:54, from /soft/OpenFOAM-v2006/OpenFOAM-v2006/src/OpenFOAM/lnInclude/VectorSpaceI.H:29, from /soft/OpenFOAM-v2006/OpenFOAM-v2006/src/OpenFOAM/lnInclude/VectorSpace.H:276, from /soft/OpenFOAM-v2006/OpenFOAM-v2006/src/OpenFOAM/lnInclude/Vector.H:48, from /soft/OpenFOAM-v2006/OpenFOAM-v2006/src/OpenFOAM/lnInclude/vector.H:42, from /soft/OpenFOAM-v2006/OpenFOAM-v2006/src/OpenFOAM/lnInclude/fieldTypes.H:37, from /soft/OpenFOAM-v2006/OpenFOAM-v2006/src/finiteVolume/lnInclude/fvMatricesFwd.H:34, from /soft/OpenFOAM-v2006/OpenFOAM-v2006/src/finiteVolume/lnInclude/fvOption.H:50, from /soft/OpenFOAM-v2006/OpenFOAM-v2006/src/fvOptions/lnInclude/cellSetOption.H:57, from codedFvOptionTemplate.H:105, from codedFvOptionTemplate.C:29: /dlocal/run/8251943/constant/fvOptions.epsilonSource: In member function ‘virtual void Foam::fv::epsilonSourceFvOptionscalarSource::addSup(const volScalarField&, Foam::fvMatrix<double>&, Foam::label)’: /dlocal/run/8251943/constant/fvOptions.epsilonSource:66:20: error: ‘cellC’ was not declared in this scope /soft/OpenFOAM-v2006/OpenFOAM-v2006/src/OpenFOAM/lnInclude/stdFoam.H:297:30: note: in definition of macro ‘forAll’ for (Foam::label i=0; i<(list).size(); ++i) ^ /dlocal/run/8251943/constant/fvOptions.epsilonSource:69:34: error: no match for ‘operator+=’ (operand types are ‘double’ and ‘Foam::tmp<Foam::DimensionedField<double, Foam::volMesh> >’) /dlocal/run/8251943/constant/fvOptions.epsilonSource:69:34: note: candidate is: /dlocal/run/8251943/constant/fvOptions.epsilonSource:69:34: note: operator+=(double&, int) <built-in> /dlocal/run/8251943/constant/fvOptions.epsilonSource:69:34: note: no known conversion for argument 2 from ‘Foam::tmp<Foam::DimensionedField<double, Foam::volMesh> >’ to ‘int’ make: *** [Make/linux64GccDPInt32Opt/codedFvOptionTemplate.o] Error 1 --> FOAM FATAL IO ERROR: Failed wmake "dynamicCode/epsilonSource/platforms/linux64GccDPInt32Opt/lib/libepsilonSource_868e6b493283f3b08eed87e0a7187b68c731d1e4.so" file: /dlocal/run/8251943/constant/fvOptions.epsilonSource at line 39 to 83. From void Foam::codedBase::createLibrary(Foam::dynamicCode&, const Foam::dynamicCodeContext&) const in file db/dynamicLibrary/codedBase/codedBase.C at line 237. FOAM parallel run exiting application called MPI_Abort(MPI_COMM_WORLD, 1) - process 0 In: PMI_Abort(1, application called MPI_Abort(MPI_COMM_WORLD, 1) - process 0) srun: Job step aborted: Waiting up to 32 seconds for job step to finish. slurmstepd: error: *** STEP 8251943.2 ON my336 CANCELLED AT 2021-05-27T13:25:55 *** srun: error: my342: tasks 28-55: Killed srun: Terminating job step 8251943.2 srun: error: my349: tasks 56-83: Killed srun: error: my336: tasks 0-27: Killed Kabir |
epsiloncodedSource: 'error: could not load dynamicCode' | Kbshariff | OpenFOAM Programming & Development | 0 | May 27, 2021 08:34 |
Load step continuation problems - Ansys Mechanical; APDL | Lapis1 | ANSYS | 0 | September 8, 2017 11:21 |
Evaluating bed load transport, bed load velocity and Shields number | chripasch | FLOW-3D | 1 | August 15, 2017 06:20 |
Get load values at each substep | ploi | ANSYS | 0 | March 10, 2016 16:07 |
Cfd to ansys thermal to ansys structural interface | ssixr | ANSYS | 17 | July 31, 2015 16:18 |
