Sultan Islam
Rep Power: 10 ![]() |
So I noticed a foam warning in Fe40 on both centos7 and ubuntu 18.04LTS whenever I try to deconpose a case. To go into detail, this only happens when the decomposition method is chosen to hierarchical or patchedConstraints. I specifically tried the simpleFoam/motobike and MRFSimpleFoam/axialturbine_ggi tutorials. The log complains as followed: Code:
--> FOAM Warning : From function decompositionMethod::loadExternalLibraries() in file decompositionMethod/decompositionMethod.C at line 508 Loading of decomposition library libparMetisDecomp.so unsuccesful. Some decomposition methods may not be available --> FOAM Warning : From function decompositionMethod::loadExternalLibraries() in file decompositionMethod/decompositionMethod.C at line 508 Loading of decomposition library metisDecomp.so unsuccesful. Some decomposition methods may not be available --> FOAM Warning : From function decompositionMethod::loadExternalLibraries() in file decompositionMethod/decompositionMethod.C at line 508 Loading of decomposition library scotchDecomp.so unsuccesful. Some decomposition methods may not be available Any help would be appreciated. Edit: Definitely seems like for certain tutorials, it tries to load the decomp libraries twice, because even with warning, decomposition completed and the solution converges. Thanks Last edited by EternalSeekerX; June 10, 2021 at 04:35. |
Manual decomposition using setFields | RL-S | OpenFOAM Pre-Processing | 8 | July 3, 2023 08:51 |
Domain decomposition of 3D overset grid case | tok3rat0r | OpenFOAM Running, Solving & CFD | 2 | February 24, 2023 02:58 |
MPI warnings | sita | OpenFOAM Running, Solving & CFD | 1 | May 9, 2019 05:46 |
[snappyHexMesh] How to define to right point for locationInMesh | Mirage12 | OpenFOAM Meshing & Mesh Conversion | 7 | March 13, 2016 14:07 |
meshing of a compound volume in GMSH | shawn3531 | OpenFOAM | 4 | March 12, 2015 10:45 |
