Diffusive flux in porous structure doesn't converge with smaller mesh
Old   May 21, 2021, 03:53
Default Diffusive flux in porous structure doesn't converge with smaller mesh
Adam
Adam_K is on a distinguished road
I've been banging my head trying to figure this out and was hoping that someone here could help shed some light on my issue.
My overall goal is the simulate the diffusion across a porous film defined by the interparticle spaces in a spherical compact. I start with a solid matrix, and then subtract a series of spheres, leaving me with a continuous mesh around the sphereical pores. Before subtracting the spheres, the sphere-sphere contact points are "trimmed" in order to avoid the issues associated with meshing the contact points (see this article for more info). Here is an example image, only the sphere-matrix interface is shown for simplicity. The smallest spheres have a radius of 1 cm:
I set-up my case using the files at the end of this post and the solve it using laplacianFoam. After completion I run the command
postProcess -func 'patchIntegrate(name=Bottom,gradTz)' -latestTime |grep 'areaIntegrate(Bottom)'
in order to calculate the integrated flux across the bottom patch (I also do this for the top patch). The flux is then used to calculate the effective diffusivity of the medium.
When I mesh using gmsh and then run the OpenFOAM simulation (files at the end), for a range of mesh critical lengths I get the following results. For smaller mesh lengths, the overall volume of the mesh and the surface area of the top and bottom surfaces start to converge and there isn't much change. However, the integrated flux divided does not converge with the mesh critical length.
Here is my O/T file
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     | Website:  https://openfoam.org
    \\  /    A nd           | Version:  8
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    object      T;
dimensions      [0 -3 0 0 1 0 0];
internalField   uniform 0.08;
boundaryField
    Top
        type            fixedValue;
        value           uniform 0.16;
    Bottom
        type            fixedValue;
        value           uniform 0;
    Left
        type            zeroGradient;
    Right
        type            zeroGradient;
    Back
        type            zeroGradient;
    Front
        type            zeroGradient;
    Interior
        type            zeroGradient;
And fvSchemes
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSchemes;
ddtSchemes
    default         steadyState;
gradSchemes
    default         Gauss linear;
    grad(T)         Gauss linear;
divSchemes
    default         none;
laplacianSchemes
    default         none;
    laplacian(DT,T) Gauss linear orthogonal;
interpolationSchemes
    default         linear;
snGradSchemes
    default         corrected;
fluxRequired
    default         yes;
    T               ;
and fvSolution
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSolution;
solvers
    T
        preconditioner  FDIC;
		solver          GAMG;
		mergeLevels		1;
		smoother 		GaussSeidel;
		agglomerator	faceAreaPair;
		nCellsInCoarsestLevel	2;
        nPreSweeps 		3;
		nPostSweeps		2;
		nFinestSweeps	2;
        tolerance       1e-10;
        relTol          0;
SIMPLE
//    nNonOrthogonalCorrectors 2;
	consistent 	yes;
	 residualControl
        T               1e-9;
and controlDict
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      controlDict;
application     laplacianFoam;
startFrom       startTime;
startTime       0;
stopAt          endTime;
endTime         10;
deltaT          1;
writeControl    timeStep;
writeInterval   1;
purgeWrite	2;
writeFormat     binary;
writePrecision  32;
writeCompression uncompressed;
timeFormat      general;
Adam_K is offline   Reply With Quote
Overset mesh for Fluid Structure Interaction in OpenFOAM Thaw Tar OpenFOAM Programming & Development 4 August 25, 2023 18:56
[snappyHexMesh] non uniform mesh near the stl object vava10 OpenFOAM Meshing & Mesh Conversion 0 January 31, 2021 15:41
Mesh interfaces and reactions in porous media - why not working? RossFS FLUENT 0 December 15, 2013 06:40
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 19:10
