Minimum allowable diameter in twoPhaseEulerFoam |
May 13, 2021, 01:52 |
Sarang Tamhankar
What is the minimum allowable diameter in twoPhaseEulerFoam solver?
While simulating bubble column using the solver I'm facing an issue where the column completely fills up with air if I reduce diameter of water droplet below 0.1mm. And if so is there any way to change this limit to allow for smaller air and water drops? I'm using a constant bubble diameter model. |
twoPhaseEulerFoam particle diameter | jagan1mohan | OpenFOAM Running, Solving & CFD | 0 | June 13, 2020 10:27 |
TwoPhaseEulerFoam - Bubble diameter size Problem | BlnPhoenix | OpenFOAM Running, Solving & CFD | 8 | September 17, 2019 16:59 |
twoPhaseEulerFoam - particle diameter distribution | Elm | OpenFOAM Pre-Processing | 2 | December 4, 2018 05:23 |
Minimum Allowable Wall Distance | rks171 | Main CFD Forum | 7 | June 16, 2012 16:39 |
The minimum diameter of second phase in the DPM | Fluenter | FLUENT | 2 | August 15, 2004 07:46 |
