icoUncoupledKinematicCloud in pre-solved flow |
May 12, 2021, 14:41 |
Arnau
Rep Power: 5 |
Hi, I am working on a project in which im solving a laminar flow through a pipe including non-coupled particle tracking (I am using icoUncoupledKinematicCloud). As the flow and the particles are not coupled, it should be possible to run the particle tracking after I have previously solved the flow. I need to do several runs for the particlle tracking and I need to avoid to solve the flow each time, as the computational cost would be unaffordable.
If someone can help me with this, it would be very helpful for me. Thanks for your help. |
icouncoupledkinematicclou, lagrangian, particletracking, presolvedflow |
mass flow inlet and pressure outlet with target mass flow rate | Zigainer | FLUENT | 13 | October 26, 2018 05:58 |
Enabling Open Channel Flow Sub-Model in Mixture model | cod213 | FLUENT | 0 | January 10, 2017 13:40 |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 01:27 |
potential flow vs. Euler flow | curious ... | Main CFD Forum | 23 | July 21, 2006 07:40 |
transform navier-stokes eq. to euler-eq. | pxyz | Main CFD Forum | 37 | July 7, 2006 08:42 |
