May 11, 2021, 06:33 |
Unstable Outlet Boundary Condition
Conor
Rep Power: 10 |
Hello there,
Could someone please advise me about the problem I am facing as seen in the attached images? There is clearly an error in the setting of the outlet boundary condition that is causing instability at the end of my simulation. It is ok for the majority for run. This error is also causing a general increase in overall pressure within the domain. My geometry is a sufficient distance from the outlet. Thanks, See below my boundary conditions: Velocity: Code:
dimensions [0 1 -1 0 0 0 0]; internalField uniform (3.5 0 0); boundaryField { inlet { type freestream; freestreamValue $internalField; } outlet { type freestream; freestreamValue $internalField; } ".*foil.*" { type movingWallVelocity; value uniform (0 0 0); } "AMI.*" { type cyclicAMI; value $internalField; } top { type slip; } bottom { type slip; } "front.*" { type slip; } "back.*" { type slip; } } Code:
dimensions [0 2 -2 0 0 0 0]; internalField uniform 0; boundaryField { inlet { type freestream; freestreamValue $internalField; } outlet { type freestream; freestreamValue $internalField; } ".*foil.*" { type zeroGradient; } top { type slip; } bottom { type slip; } "front.*" { type slip; } "back.*" { type slip; } "AMI.*" { type cyclicAMI; value $internalField; } } |
May 11, 2021, 07:10 |
Conor
Rep Power: 10 |
Sorry,
It is an external flow case of a wind turbine. I am using pimpleFoam. I am using an initial coarse timestep of 0.01. I will be seeking a max Courant number of 2 thereafter. Turbulence model is SA I will be pressure mapping one of the foils for an FSI model. This error is causing an increase in pressure in the domain and thus is impacting this pressure map. |
CFD analaysis of Pelton turbine | amodpanthee | CFX | 31 | April 19, 2018 19:02 |
Question about adaptive timestepping | Guille1811 | CFX | 25 | November 12, 2017 18:38 |
volumetric flow rate is fluctuating in outlet boundary condition location | oozcan | FLUENT | 1 | November 30, 2016 04:00 |
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 06:15 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 07:20 |
