The free surface is abnormal after the mesh is thinner |
May 11, 2021, 00:37 |
liqianrong
Hi guys!
I am calculating the total drag coefficient of a ship in calm water. Two different grids are used. The total drag coefficient converges with the coarse grid and the free surface is normal (Figure 1, 2). But the fine grid is used. The total resistance coefficient of the calculation example does not converge, and the free liquid surface is abnormal (Figure 3, 4). Can anyone tell me the reason for this? I put these two case files below. |
May 12, 2021, 04:27 |
Figure1-4
liqianrong
Figure1 Figure2 Figure3 Figure4 |
May 15, 2021, 15:10 |
a bit of help
Paulin FERRO
Rep Power: 5 |
It looks like your are using a too large time step for your fine grid. Possible solution : - decrease your time step. - increase the number of outer correctors - increase the number of sub cycle for the alpha.water resolution. Good luck |
resistance coefficient |
foam-extend-4.1 release | hjasak | OpenFOAM Announcements from Other Sources | 19 | July 16, 2021 06:02 |
[snappyHexMesh] problems generating clean mesh | Christian_tt | OpenFOAM Meshing & Mesh Conversion | 2 | June 20, 2019 06:39 |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 09:54 |
[snappyHexMesh] SHM problem : KVLCC2 with appendage mesh | sc.park | OpenFOAM Meshing & Mesh Conversion | 1 | March 13, 2016 14:28 |
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation | tommymoose | ANSYS Meshing & Geometry | 48 | April 15, 2013 05:24 |
