Foam-Extend 4.0 simpleFoam motorbike parallel error?
Old   May 10, 2021, 05:55
Unhappy Foam-Extend 4.0 simpleFoam motorbike parallel error?
Sultan Islam
EternalSeekerX is on a distinguished road
Hello everyone!
So I compiled Foam-Extend 4.0 and wanted to test the install using motorbike. I modified the Allrun to look like this:
#!/bin/sh
# Source tutorial run functions
. $WM_PROJECT_DIR/bin/tools/RunFunctions
runApplication blockMesh
runApplication snappyHexMesh
\rm -rf constant/polyMesh
\mv 3/polyMesh constant
\rm -rf 1 2 3
#runApplication simpleFoam
runApplication decomposePar
runApplication mpirun -np 6 simpleFoam
runApplication reconstructPar
However decomposePar throws these errors:
| \\      /  F ield         | foam-extend: Open Source CFD                    |
|  \\    /   O peration     | Version:     4.0                                |
|   \\  /    A nd           | Web:         http://www.foam-extend.org         |
|    \\/     M anipulation  | For copyright notice see file Copyright         |
Build    : 4.0-268bb07d15d8
Exec     : decomposePar
Date     : May 10 2021
Time     : 04:56:42
Host     : eXohost
PID      : 24674
CtrlDict : "/home/si/Documents/OpenFOAM/Foam-Extend-4.0/Tutorials/Incompressible/simpleFoam/motorBike/system/controlDict"
Case     : /home/si/Documents/OpenFOAM/Foam-Extend-4.0/Tutorials/Incompressible/simpleFoam/motorBike
nProcs   : 1
SigFpe   : Enabling floating point exception trapping (FOAM_SIGFPE).
Create time
Time = 0
Create mesh for region region0
Calculating distribution of cells
--> FOAM Warning :
    From function decompositionMethod::loadExternalLibraries()
    in file decompositionMethod/decompositionMethod.C at line 508
    Loading of decomposition library libparMetisDecomp.so unsuccesful. Some decomposition methods may not be  available
Selecting decompositionMethod hierarchical
Finished decomposition in 0.4 s
Calculating original mesh data
Distributing cells to processors
Distributing faces to processors
Calculating processor boundary addressing
Distributing points to processors
Constructing processor meshes
Processor 0
    Number of cells = 56550
    Number of faces shared with processor 1 = 1802
    Number of faces shared with processor 3 = 3715
    Number of faces shared with processor 4 = 2
    Number of processor patches = 3
    Number of processor faces = 5519
    Number of boundary faces = 10182
Processor 1
    Number of faces shared with processor 0 = 1802
    Number of faces shared with processor 2 = 1209
    Number of faces shared with processor 4 = 3181
    Number of faces shared with processor 3 = 42
    Number of processor patches = 4
    Number of processor faces = 6234
    Number of boundary faces = 12486
Processor 2
    Number of cells = 56551
    Number of faces shared with processor 1 = 1209
    Number of faces shared with processor 5 = 4750
    Number of faces shared with processor 4 = 45
    Number of processor faces = 6004
    Number of boundary faces = 1970
Processor 3
    Number of faces shared with processor 0 = 3715
    Number of faces shared with processor 4 = 1746
    Number of faces shared with processor 1 = 42
    Number of processor faces = 5503
    Number of boundary faces = 10543
Processor 4
    Number of faces shared with processor 1 = 3181
    Number of faces shared with processor 3 = 1746
    Number of faces shared with processor 5 = 1416
    Number of faces shared with processor 2 = 45
    Number of faces shared with processor 0 = 2
    Number of processor patches = 5
    Number of processor faces = 6390
    Number of boundary faces = 12122
Processor 5
    Number of faces shared with processor 2 = 4750
    Number of faces shared with processor 4 = 1416
    Number of processor patches = 2
    Number of processor faces = 6166
    Number of boundary faces = 1911
Number of processor faces = 17908
Max number of processor patches = 5
Max number of faces between processors = 6390
--> FOAM Serious Error :
    From function IOobject::readHeader(Istream&)
    in file db/IOobject/IOobjectReadHeader.C at line 89
    Reading "/home/si/Documents/OpenFOAM/Foam-Extend-4.0/Tutorials/Incompressible/simpleFoam/motorBike/0/fixedInlet" at line 9
    First token could not be read or is not the keyword 'FoamFile'
Check header is of the form:
FoamFile
    version     2.0;
    format      ascii;
    class       IOobject;
    location    "0";
    object      fixedInlet;
    Reading "/home/si/Documents/OpenFOAM/Foam-Extend-4.0/Tutorials/Incompressible/simpleFoam/motorBike/0/frontBackUpperPatches" at line 9
FoamFile
    version     2.0;
    format      ascii;
    class       IOobject;
    location    "0";
    object      frontBackUpperPatches;
    Reading "/home/si/Documents/OpenFOAM/Foam-Extend-4.0/Tutorials/Incompressible/simpleFoam/motorBike/0/initialConditions" at line 9
FoamFile
    version     2.0;
    format      ascii;
    class       IOobject;
    location    "0";
    object      initialConditions;
Processor 0: field transfer
Processor 1: field transfer
Processor 2: field transfer
Processor 3: field transfer
Processor 4: field transfer
Processor 5: field transfer
End.
My allmake logs show no errors and shows everything is built. Anyone have any ideas? Why can't it find parmetis decomp and why is it throwing those other errors
EternalSeekerX is offline   Reply With Quote
[OpenFOAM] ParaView command in Foam-extend-4.1 mitu_94 ParaView 0 March 4, 2021 14:46
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) Yogini Fluent UDF and Scheme Programming 7 October 3, 2012 08:24
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 07:42
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
user subroutine error CFDUSER CFX 2 December 9, 2006 07:31
