NACA0012 does not get the result of the stall |
May 9, 2021, 05:18 |
cheng
Rep Power: 5 |
Hello everyone, I am now using openfoam to compare with experimental data. The results compare well before the stall. But when there is a stall situation and the lift coefficient should decrease, my lift coefficient is still increasing. Can someone tell me why this is. I am using simpleFoam, SA model.
May 9, 2021, 12:17 |
Herpes Free Engineer
Rep Power: 13 |
I don't think there is a RANS or even hybrid RANS-LES setup that can predict the polar coefficients correctly for a given airfoil at stall and post-stall regions.
The OpenFOAM community is the biggest contributor to OpenFOAM: User guide/Wiki-1/Wiki-2/Code guide/Code Wiki/Journal Nilsson/Guerrero/Holzinger/Holzmann/Nagy/Santos/Nozaki/Jasak/Primer Governance Bugs/Features: OpenFOAM (ESI-OpenCFD-Trademark) Bugs/Features: FOAM-Extend (Wikki-FSB) Bugs: OpenFOAM.org How to create a MWE New: Forkable OpenFOAM mirror |
May 9, 2021, 15:28 |
Rep Power: 14 |
openfoam,stall,sa |
Can not get the right result at AoA=10 for RANS simulation of the NACA0012 | liujmljm | SU2 | 2 | August 19, 2013 02:25 |
MRFSimpleFoam result checking | Aadhavan | OpenFOAM Running, Solving & CFD | 0 | December 8, 2012 05:52 |
2D External flow over NACA0012 | DBFIU | Main CFD Forum | 7 | July 13, 2011 14:26 |
Rotating Stall in Centrifugal Compressors | Paul den Held | Main CFD Forum | 3 | October 11, 2000 03:50 |
stall | yin | Main CFD Forum | 1 | May 10, 2000 04:03 |
