May 7, 2021, 06:00 |
data oscillations in overset v2006
ROIN bin
Rep Power: 6 |
Hi all!
I´m doing a simulation with overset meshes. I ran already the tutorials that come with the version v2006.The simulation results are in line with expectations, but there are many numerical oscillations in lift and drag. I don't know what caused this, or overset itself will have such a result. Below are my results and fv settings, please give me some suggestions, thank you. fvschemes Code:
ddtSchemes { default Euler; } gradSchemes { default Gauss linear; grad(T) Gauss linear; } divSchemes { default none; div(phi,U) Gauss limitedLinearV 1; div(phi,k) Gauss limitedLinear 1; div(phi,epsilon) Gauss limitedLinear 1; div(phi,R) Gauss limitedLinear 1; div(R) Gauss linear; div(phi,nuTilda) Gauss limitedLinear 1; div((nuEff*dev(T(grad(U))))) Gauss linear; div((nuEff*dev2(T(grad(U))))) Gauss linear; } laplacianSchemes { default Gauss linear corrected; laplacian(diffusivity,cellDisplacement) Gauss linear corrected; } interpolationSchemes { default linear; } snGradSchemes { default corrected; } oversetInterpolation { method inverseDistance; //method trackingInverseDistance; //searchBoxDivisions 2{(100 100 1)}; } fluxRequired { default no; pcorr ; p ; } Code:
solvers { cellDisplacement { solver PCG; preconditioner DIC; tolerance 1e-06; relTol 0; maxIter 100; } p { solver PBiCGStab; preconditioner DILU; tolerance 1e-6; relTol 0; } pFinal { $p; } pcorr { $p; solver PCG; preconditioner DIC; } pcorrFinal { $pcorr; relTol 0; } "(U|k|epsilon)" { solver smoothSolver; smoother symGaussSeidel; tolerance 1e-6; relTol 0; } "(U|k|epsilon)Final" { $U; tolerance 1e-6; relTol 0; } } PIMPLE { momentumPredictor no; correctPhi no; nOuterCorrectors 1; nCorrectors 2; nNonOrthogonalCorrectors 0; ddtCorr false; pRefPoint (0.0001 0.0001 0.001); pRefValue 0.0; } relaxationFactors { fields { } equations { ".*" 1; } } |
drag oscillations overset |
UDF value to large for defined data type | Anna73 | Fluent UDF and Scheme Programming | 9 | September 30, 2018 22:18 |
A CFX-POST error (ver 14.5.7) | wangyflp88 | CFX | 2 | July 22, 2017 00:17 |
Data Produced From Fine Marine Cant Match with The Experimental Data | PeiSan | Fidelity CFD | 4 | August 23, 2014 05:33 |
Problem running in parralel | Val | OpenFOAM Running, Solving & CFD | 1 | June 12, 2014 02:47 |
How to update polyPatchbs localPoints | liu | OpenFOAM Running, Solving & CFD | 6 | December 30, 2005 17:27 |
