reconstructPar error: cannot find pointProcAdressing
Old   May 4, 2021, 08:04
Default reconstructPar error: cannot find pointProcAdressing
Istanbul
anilbekgoz is on a distinguished road
Hey guys!
I am experimenting on a very simple multi-region case. Internal heat generation in a solid box & forced air cooling on it.
I use snappyHexMesh on 4 cores (decompose: scotch) and then run chtMultiRegionFoam. When I try to reconstruct it I get the following error:
--> FOAM FATAL ERROR:
cannot find file "/home/anil/initialDemos/boxAllrun/processor0/constant/fluid/polyMesh/pointProcAddressing"
    From function virtual Foam::autoPtr<Foam::ISstream> Foam::fileOperations::uncollatedFileOperation::readStream(Foam::regIOobject&, const Foam::fileName&, const Foam::word&, bool) const
    in file global/fileOperations/uncollatedFileOperation/uncollatedFileOperation.C at line 538.
FOAM exiting
I am using OpenFOAM 8 on a Ubuntu 20.04. Any help is much appreciated.
Allrunmesh:
#!/bin/sh
cd ${0%/*} || exit 1
. $WM_PROJECT_DIR/bin/tools/RunFunctions
rm -rf constant/polyMesh/sets
runApplication blockMesh
runApplication decomposePar -copyZero
runParallel snappyHexMesh -overwrite
runParallel splitMeshRegions -cellZones -overwrite
Allrun:
#!/bin/sh
runParallel $(getApplication)
runApplication reconstructPar -allRegions
All the best,
Anil
anilbekgoz is offline   Reply With Quote
chtmultiregionfoam, openfoam8, parallel, reconstructpar
Coupling with MATLAB via Java, getting the message: "error: cannot find symbol" Dry Patrick STAR-CCM+ 6 October 23, 2018 10:03
/usr/bin/ld: cannot find -llagrangianTurbulence /usr/bin/ld: cannot find -lfluidTherm Luiggito OpenFOAM Programming & Development 9 May 2, 2016 01:54
CFX-Pre problem, pls help!!! cth_yao CFX 0 February 17, 2012 01:52
OpenFOAM 1.6-ext git installation on Ubuntu 11.10 x64 Attesz OpenFOAM Installation 45 January 13, 2012 13:38
Problem Building OF on Centos cluster (no admin rights) CKH OpenFOAM Installation 5 November 13, 2011 07:32
