April 25, 2021, 06:13 |
solving ship resistance divergence
Jiayu Sun
Rep Power: 6 |
Dear Foamers and Ship designers:
I am doing the ship resistance simulation refering to DTCHull setting. I think the only changes I made are the mesh and initial value of turbulence variables. The mesh is encrypted near the hull,as shown in the figure below.The initial value of turbulence variables are caculated by the formula in this paper HTML Code:
https://scholar.google.com/scholar?q=Uncertainty+analysis+in+ship+resistance+prediction+using+OpenFOAM&hl=zh-CN&as_sdt=0&as_vis=1&oi=scholart Any suggestions? Thank you in advance. Jiayu Sun |
April 26, 2021, 04:43 |
Solved
Jiayu Sun
Rep Power: 6 |
FYI:
Problems caused by incomplete boundary coverage when setting phase fraction field. The oscillation caused by the physical model is more obvious than that caused by the numerical scheme. |
divergence problem, ship resistance |
laplacianFoam with source term | Herwig | OpenFOAM Running, Solving & CFD | 17 | November 19, 2019 14:47 |
Segmentation fault when using reactingFOAM for Fluids | Tommy Floessner | OpenFOAM Running, Solving & CFD | 4 | April 22, 2018 13:30 |
conjugate heat transfer in OpenFOAM | skuznet | OpenFOAM Running, Solving & CFD | 99 | March 16, 2017 06:07 |
simpleFoam error - "Floating point exception" | mbcx4jc2 | OpenFOAM Running, Solving & CFD | 12 | August 4, 2015 03:20 |
calculation stops after few time steps | sivakumar | OpenFOAM Running, Solving & CFD | 7 | March 17, 2013 07:37 |
