Atmospheric Boundary Layer Flow Field Won't Change |
April 23, 2021, 13:13 |
Kim Best
Rep Power: 5 |
I'm trying to simulate the effect of varying inlet velocity on a single 2D sinusoidal hill in an neutral atmospheric boundary layer. Everything runs without errors, however when I vary the inlet velocity the flow field is the same for all simulations. By this I mean, the velocities do scale as they should, but there is no non-linearity due to the presence of the hill. I am using the turbineSiting tutorial as a template with all the boundary conditions unchanged (I intent to also simulate the presence of actuator disks, but the problem is the same with or without them) and the same k-epsilon turbulence model. The mesh is scaled down so the hill has a height of 0.04 m (my reference height for u*). If I run the simulations for very low speeds (<12 m/s), there is no separation across the hill. Higher than this means the number of timesteps diverges, but then the case converges again when the inlet velocity is around 25 m/s and above. In both cases where I have convergence, the flow field looks exactly the same when I scale to each ones data range in paraView. I have added a layer to the mesh so that the first cell centre height (=0.84mm) is greater than Ks (=0.08mm, where z0 is 4e-6m). I think that the problem may lie here however I'm pretty sure I have done this right. Any help would be great as I'm runnning out of time on this project and have tried everything! I have attached all the relevant files for running my case in how it differs from the turbineSiting tutorial. Thanks, Kim |
abl flow, layers addition, terrain, turbinesiting |
Wind turbine simulation | Saturn | CFX | 60 | July 17, 2024 06:45 |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 07:40 |
Table bounds warnings at: END OF TIME STEP | CFXer | CFX | 4 | July 17, 2020 00:44 |
Question about adaptive timestepping | Guille1811 | CFX | 25 | November 12, 2017 18:38 |
[snappyHexMesh] Boundary layer generation problems | ivan_cozza | OpenFOAM Meshing & Mesh Conversion | 0 | October 6, 2010 14:47 |
