rhoSimpleFoam and externalWallHeatFluxTemperature issue
Old   April 12, 2021, 12:16
Default rhoSimpleFoam and externalWallHeatFluxTemperature issue
Matt
mattmirsad is on a distinguished road
Dear FOAMers,
I am trying to solve a simple internal flow case in a pipe with rhoSimpleFoam where an external heat flux is specified using "externalWallHeatFluxTemperature" as shown in the code below:
|  \\    /   O peration     | Version:  v2012                                 |
|   \\  /    A nd           | Website:  www.openfoam.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    object      T;
dimensions      [0 0 0 1 0 0 0];
internalField   uniform 300;
boundaryField
    Inlet
        type            fixedValue;
        value           $internalField;
    outlet
        type            inletOutlet;
        inletValue      $internalField;
    sides
        type            externalWallHeatFluxTemperature;
		mode            coefficient;
        Ta              constant 700.0;
        h               constant 1000.0;
        thicknessLayers (0.001 0.002);
        kappaLayers     (1 2.5);
        kappaMethod     fluidThermo;
The solver runs smoothly without any problem and the results are reasonable. But if I only change the "sides" boundary condition to uniform heat flux (as shown below), the solver stops in the first iteration without any error message!
PHP Code:
FoamFile
version     2.0;
format      ascii;
    class
volScalarField;
object      T;
boundaryField
Inlet
type            fixedValue;
outlet
type            inletOutlet;
sides
mode            flux;
q               uniform 111// W/m^2
kappa           none;
Qr              none;
In a nutshell, mode "coefficient" works perfectly but mode "flux" cause the solver to crash without any error message. Here is how the solver stops:
PHP Code:
Time 1
GAMG
:  Solving for UxInitial residual 1, Final residual 0.0495507No Iterations 2
GAMG
:  Solving for UyInitial residual 1, Final residual 0.0551383No Iterations 2
GAMG
:  Solving for UzInitial residual 1, Final residual 0.0278211No Iterations 1
Could you please share your thoughts on the possible root causes for this?
Cheers,
Matt
mattmirsad is offline   Reply With Quote
Old   April 13, 2021, 03:04
Roman
Roman1 is on a distinguished road
One of the possible reason is unbalance between heat flux from gas media to solid wall and fixed heat flux that you have written as boundary condition. For example, cell size, temperature, gas speed can not provide desired 111 w/sq.m from gas phase to solid. So heat flux from gas becomes unequal to heat flux from surface into solid, continuity becomes broken, program stops.
Roman1 is offline   Reply With Quote
Old   April 13, 2021, 09:24
Matt
Thanks for your response.
I just did some more tests with this case:
For the case described above, I am using "OpenFOAM-v2012-windows10".
if I transfer it to a LINUX system I get more information when it crashes:
PHP Code:
|  \\    /   O peration     | Version:  2012                                  |
Build  79e353b8-20201222 OPENFOAM=2012
Arch
"LSB;label=32;scalar=64"
Exec   rhoSimpleFoam
Date
Apr 13 2021
Time
13:24:16
Host
xxxxxxxxxxxxxxxxxxxx
PID
2462
I
/O    uncollated
Case   : /home/matt/OpenFOAM_ESI/rhoSF/squareBend_To_Pipe
nProcs
1
trapFpe
Floating point exception trapping enabled (FOAM_SIGFPE).
fileModificationChecking Monitoring run-time modified files using timeStampMaster (fileModificationSkew 5maxFileModificationPolls 20)
allowSystemOperations Allowing user-supplied system call operations
Create time
Create mesh
for time 0
SIMPLE
convergence criteria
    field p tolerance 0.001
    field U tolerance 0.0001
    field e tolerance 0.001
    field
"(k|epsilon)" tolerance 0.001
Reading thermophysical properties
Selecting thermodynamics package
type            heRhoThermo;
mixture         pureMixture;
transport       sutherland;
thermo          hConst;
equationOfState perfectGas;
specie          specie;
energy          sensibleInternalEnergy;
Reading field U
Reading
/calculating face flux field phi
pressureControl
    pMax 220000
    pMin 11000
Creating turbulence model
Selecting turbulence model type RAS
Selecting RAS turbulence model kEpsilon
RAS
RASModel        kEpsilon;
turbulence      on;
printCoeffs     on;
Cmu             0.09;
C1              1.44;
C2              1.92;
C3              0;
sigmak          1;
sigmaEps        1.3;
No MRF models present
No finite volume options present
Starting time loop
wallHeatFlux wallHeatFlux1
processing wall patches:
sides
Time
1
GAMG
GAMG
GAMG
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::sigFpe::sigHandler(int) at ??:?
#2  ? in /lib/x86_64-linux-gnu/libpthread.so.0
#3  Foam::heThermo<Foam::rhoThermo, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy> > > >::he(Foam::Field<double> const&, Foam::Field<double> const&, int) const at ??:?
#4  Foam::mixedEnergyFvPatchScalarField::updateCoeffs() at ??:?
#5  Foam::fvMatrix<double>::fvMatrix(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::dimensionSet const&) in /usr/lib/openfoam/openfoam2012/platforms/linux64GccDPInt32Opt/bin/rhoSimpleFoam
#6  Foam::tmp<Foam::fvMatrix<double> > Foam::fv::optionList::operator()<double>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::word const&) in /usr/lib/openfoam/openfoam2012/platforms/linux64GccDPInt32Opt/bin/rhoSimpleFoam
#7  ? in /usr/lib/openfoam/openfoam2012/platforms/linux64GccDPInt32Opt/bin/rhoSimpleFoam
#8  __libc_start_main in /lib/x86_64-linux-gnu/libc.so.6
#9  ? in /usr/lib/openfoam/openfoam2012/platforms/linux64GccDPInt32Opt/bin/rhoSimpleFoam
Floating point exception (core dumped
The interesting point is that if I use openFOAM foundation on a LINUX system this problems runs smoothly without any problem!
Any more thoughts on this are appreciated.
Cheers,
Matt
rhosimplefoam error
transsonic nozzle with rhoSimpleFoam Unseen OpenFOAM Running, Solving & CFD 8 July 1, 2022 07:54
rhoSimpleFoam and externalWallHeatFluxTemperature issue mattmirsad OpenFOAM Running, Solving & CFD 0 April 12, 2021 12:11
rhoSimpleFoam Spalart Allmaras simulation issue mariloo OpenFOAM Running, Solving & CFD 0 December 4, 2019 12:09
rhoSimpleFoam convergence issue fxzf OpenFOAM Running, Solving & CFD 2 August 28, 2017 05:37
rhoSimpleFoam angledDuctExplicitFixedCoeff tutorial fails in parallel donQi OpenFOAM Running, Solving & CFD 1 February 22, 2016 20:47
