How to change/set different boundary condition for particular cell region?
Old   May 3, 2021, 01:34
Sunag R A
sunagra27 is on a distinguished road
Dear Robin,
Certainly somewhere is a mistake, but it is getting difficult to spot without the case.
What points do you mean by points (face vertices)? It would be good to do pointSet from patch faceCentres so it gives you same number of faces as you give it the points.
I believe that these points are points of face vertices only. I created pointSet and also faceSet from these obtained pointSet. I have attached the difference in visualization from original (temp = 0) and obtained BC after creating patch from createPatch.
I will work with faceCentres directly to get pointSet and update the same.
Nevertheless, I assume that you access the patch already in your function in ControlDict and that you also iterate over the patch faces. Then you can try to do something like this
forAll(mesh.boundary()[patch], facei)
const label& face = boundaryMesh[patch].start() + facei;
I tried implementing the code in 0/patch/T, but it did not produce any result and gave me some errors related to this mainly "forAll" loop. I am trying to work with this.
Below is the implementation.
gland
        type            codedFixedValue;
        value           #include "actualSkinData";
    name        glandsurface;
    code
    const fvPatch& mesh = this->patch();
    const vectorField& Cf = mesh.Cf();
    const fvBoundaryMesh& boundaryMesh = mesh.boundaryMesh();
            const label& face = boundaryMesh[patch].start() + facei;        // Face index
Images
https://drive.google.com/file/d/1i_q...ew?usp=sharing
1st image represents the temp values applied to the surface from external file and ran for 1 iteration. The pink dots are points which are extracted from controlDict #includeFunc surfaces. From this, faceCentres are also extracted.
https://drive.google.com/file/d/1zxf...ew?usp=sharing
2nd Image is the cropped image to show the difference between temp values of where it is divided.
https://drive.google.com/file/d/1aOB...ew?usp=sharing
3rd image is the patch divided image from points. Here green color represents the patch obtained after faceSet creation. In this, some faces with T=0 are missing.
https://drive.google.com/file/d/1pBI...ew?usp=sharing
4th image is the cropped image of the new BC. Comparing 2nd and 4th cropped images, along the edges of the temp gradient, some faces are not captured from pointSet.
I can provide you the complete case.
Regards,
Sunag R A.
sunagra27 is offline   Reply With Quote
boundary condition, chtmultiregionsimpefoam, heat and mass transfer, temperature
[Other] refineWallLayer Error Yuby OpenFOAM Meshing & Mesh Conversion 2 November 11, 2021 12:04
Fatal overflow in linear solver. iamnotfajar CFX 9 October 28, 2020 05:47
accessing internal cell gradient field at boundary when applying boundary condition vishalsacharya OpenFOAM Programming & Development 7 February 25, 2019 16:36
Problem in setting Boundary Condition Madhatter92 CFX 12 January 12, 2016 05:39
Warning 097- AB Siemens 6 November 15, 2004 05:41
