cyclicTemperatureFoam
Old   March 29, 2021, 14:43
Default cyclicTemperatureFoam
Sai Guruprasad Jakkala
saiguruprasad is on a distinguished road
I am trying to use the cyclicTemperatureFoam developed by Jakob for my problem. I downloaded the file from here.
I am using OpenFOAM-v1912 for my simulations. I downloaded the solver and finished compiling it. I tried to run a sample case and an error occurs
|  \\    /   O peration     | Version:  v1912                                 |
|   \\  /    A nd           | Website:  www.openfoam.com                      |
Build  : _f3950763fe-20191219 OPENFOAM=1912
Arch   : "LSB;label=64;scalar=64"
Exec   : cyclicTemperatureFoam
Date   : Mar 29 2021
Time   : 13:36:19
Host   : linux
PID    : 10616
I/O    : uncollated
Case   : /OpenFOAM/run/cyclic_temp_trial
nProcs : 1
trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE).
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
PIMPLE: Operating solver in PISO mode
Reading field p
AMI: Creating addressing and weights between 373 source faces and 373 target faces
AMI: Patch source sum(weights) min:1 max:1 average:1
AMI: Patch target sum(weights) min:1 max:1 average:1
AMI: Creating addressing and weights between 1088 source faces and 1222 target faces
AMI: Patch source sum(weights) min:0.776249 max:1.09651 average:0.99923
AMI: Patch target sum(weights) min:0.808243 max:1 average:0.999577
Reading field U
Reading field T
Reading transportProperties
--> FOAM FATAL IO ERROR:
Wrong token type - expected word, found on line 22: double 0.84499
file:
/OpenFOAM/run/cyclic_temp_trial/constant/transportProperties.Pr at line 22.
    From function Foam::Istream& Foam::operator>>(Foam::Istream&, Foam::word&)
    in file primitives/strings/word/wordIO.C at line 78.
FOAM exiting
I believe that the error can be because of compiling for different versions and definitions in the code could have changed. I would like to know what changes I need to make to make it work in OpenFOAM-v1912.
saiguruprasad is offline   Reply With Quote
Old   March 29, 2021, 14:53
Default Solution
Solved it. The entries in the transportProperties need to be mentioned twice. I have attached the transportProperties file for clarity.
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      transportProperties;
transportModel Newtonian;
// Laminar viscosity
nu              3.22118e-05;
Pr Pr [0 0 0 0 0 0 0]  0.84499;
// Thermal expansion coefficient
beta            2.4659e-03;
gamma gamma [0 -1 0 1 0 0 0]       0.01;
// Reference temperature
//TRef            573;
Twall Twall [0 0 0 1 0 0 0]            573;
Lc Lc [0 1 0 0 0 0 0]            3.45e-3;
//rhoRef            239.25;
// Laminar Prandtl number
//Pr  0.84499;
// Turbulent Prandtl number
Prt Prt [0 0 0 0 0 0 0]     0.85;
Old   March 29, 2021, 15:00
Default Error while running
I tried to run the simulation using cyclicTemperatureFoam and it ended in error after solving for the T equation. The error was:
Date   : Mar 29 2021
Time   : 13:57:58
Host   : linux
PID    : 12334
I/O    : uncollated
nProcs : 1
Create time
Reading field p
Reading field U
Reading field T
Selecting incompressible transport model Newtonian
Selecting turbulence model type laminar
Selecting laminar stress model Stokes
No MRF models present
Creating finite volume options from "constant/fvOptions"
Selecting finite volume options type meanVelocityForce
    Source: momentumSource
    - selecting all cells
    - selected 526456 cell(s) with volume 9.06003e-08
    Initial pressure gradient = 0
Starting time loop
Courant Number mean: 0.117542 max: 4.13153
Time = 5e-07
PIMPLE: iteration 1
GAMG:  Solving for p, Initial residual = 1, Final residual = 0.00883685, No Iterations 9
time step continuity errors : sum local = 2.55973e-05, global = -7.47222e-07, cumulative = -7.47222e-07
Pressure gradient source: uncorrected Ubar = 6.59483, pressure gradient = 5.52406e+06
GAMG:  Solving for p, Initial residual = 0.787111, Final residual = 9.231e-09, No Iterations 37
time step continuity errors : sum local = 3.56132e-07, global = -3.55975e-07, cumulative = -1.1032e-06
Pressure gradient source: uncorrected Ubar = 6.76869, pressure gradient = 5.12475e+06
DILUPBiCGStab:  Solving for T, Initial residual = 1, Final residual = 2.46586e-09, No Iterations 4
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::sigSegv::sigHandler(int) at ??:?
#2  ? in /lib64/libc.so.6
#3  ? at cyclicTemperatureFoam.C:?
#4  ? at ??:?
#5  __libc_start_main in /lib64/libc.so.6
#6  ? at ??:?
Segmentation fault (core dumped)
Anyone has an idea, why this error comes up?
Old   March 29, 2021, 22:38
Default Solution to the sigSegv
The patches in the Nu.H of the solver needs to be changed to avoid the error.
In the original file, the patches mentioned were 'walls' and 'inlet'. I changed it to the respective ones from my mesh and the code was running without errors.
cyclic heat transfer, openfoam
