Time varying Temperature in a Region for chtMultiRegionFoam
Old   March 28, 2021, 23:34
Default Time varying Temperature in a Region for chtMultiRegionFoam
Desh
dasith0001 is on a distinguished road
Hi All,
I am new to OF and trying to develop a conjugate heat transfer model with chtMultiRegionFoam.
A region called 'heater' is defined and it radiates and convects heat energy. hence the boundary is defined 'compressible::turbulentTemperatureRadCoupledMixed '.
Now I want to input temperature as a function of time only to the heater region.
OF allows me to change the boundary condition with the following set-up;
boundaryField
type uniformFixedValue;
uniformValue table
(0 750)
(5 800)
(10 850)
(15 900)
"heater_to_.*"
type compressible::turbulentTemperatureRadCoupledMixed;
Tnbr T;
kappaMethod solidThermo;
value uniform 300;
1. how can I make the "heater_to_.*" boundary temperature also as a function of time?
2. The above only works for interfaces that do not define radiate or convect. how can I vary the internal field temperature of the region 'heater'?
3. using a constant or time-varying power source to the heater is an option too, but is it possible to use the temperature as the time dependant input?
I would really appreciate it if anyone can direct me or advise me on how to change the temperature in the heater region as a function of time, whilst enabling some boundaries to radiate and convect heat.
I hope the problem is clear, if not, please ask.
Thank you very much
Dasith
dasith0001 is offline   Reply With Quote
Problem with chtMultiregionFoam radiation boundary condition baran_foam OpenFOAM Running, Solving & CFD 10 December 17, 2019 18:36
Problem simulating the temperature rise in a composite material (chtMultiRegionFoam) Adam_K OpenFOAM Running, Solving & CFD 2 March 27, 2019 07:51
Stuck in a Rut- interDyMFoam! xoitx OpenFOAM Running, Solving & CFD 14 March 25, 2016 08:09
Time varying ambient temperature as B.C in OpenFoam Kumudu Main CFD Forum 0 October 24, 2013 15:08
mixerVesselAMI2D's mass is not balancing sharonyue OpenFOAM Running, Solving & CFD 6 June 10, 2013 10:34
