explicitPorositySource in multiphaseEulerFoam
Old   March 24, 2021, 12:49
Default explicitPorositySource in multiphaseEulerFoam
Mayur Sathe
mayursathe is on a distinguished road
I am trying to model flow distribution by a porous plate in the pipe. I was basing my case on the angleDuct fvoptions file.
My geometry is a larger cylindrical pipe (0.1 m dia, 0.6 m length; with a small cocentric jet inlet at y=0). the baffle plate should spread the velocity profile and make the flow uniform across the cross section.
I have defined a cell zone using topoSet as follows. the cell zone occupied the full cross section of pipe, and ran from y=0.2 - 0.25.
actions
        name    porousBaffle1;
        type    cellSet;
        action  new;
        source   boxToCell;
        sourceInfo
        box (-0.06 0.2 -0.06) (0.06 0.25 0.06);
        name    porousBaffle1;
        type    cellZoneSet;
        action  new;
        source  setToCellZone;
        sourceInfo
        set     porousBaffle1;
And I have added an fvOptions file, with the following source term definition:
porosity1
    type          explicitPorositySource;
    active        true; //yes;
    explicitPorositySourceCoeffs
        selectionMode cellZone;
cellZone      porousBaffle1;
        type fixedCoeff;
        fixedCoeffCoeffs
              alpha    alpha [0 0 -1 0 0 0 0] (5000 5000 5000); //linear term
              beta     beta [0 -1 0 0 0 0 0] (1000 1000 1000); //squared term
              coordinateSystem
        type cartesian;
        origin (0 0.2 0);
        rho 1.2;
        coordinateRotation
            type axesRotation;
            e1    (1 0 0);
            e2    (0 1 0);
                //e3    (0 0 1);
As shown in the attached image, the jet moves right through the porous zone. The pressure drop from the porous zone should block it; but looks like the explicitPorositySource is not working at all. I tried reading many forum posts but no mention of using porous zone for bubbly flow.
Can you please help me resolve this?
mayursathe is offline   Reply With Quote
explicitporositysource, fvoptions, multiphaseeulerfoam
volume fraction problem in multiphaseEulerFoam vishalgarg474 OpenFOAM Running, Solving & CFD 2 September 15, 2021 17:19
multiphaseEulerFoam: How to specify the continuous/dispersed phase nov.t OpenFOAM Running, Solving & CFD 20 March 19, 2021 07:58
multiphaseinterfoam and multiphaseeulerfoam maybee OpenFOAM Programming & Development 21 September 2, 2018 10:30
multiphaseInterFoam vs multiphaseEulerFoam rahulksoni OpenFOAM 0 August 11, 2017 03:14
Adding Boussinesq Approximation to multiphaseEulerFoam? dschmidt OpenFOAM Programming & Development 1 January 16, 2017 17:40
