unphysical volume fraction in twophaseeulerfoam |
March 16, 2021, 05:50 |
Thibaut
Rep Power: 6 |
I'm trying to run a case in which a flow drags particles around a prism. After a few time iterations, I have wrong volume fraction. For example : "alpha.particles volume fraction = 0.0152091 Min(alpha.particles) = -0.0201645 Max(alpha.particles) = 1.21005" Moreover this case "runs" for few iteration with low velocity. I'd like, at the end of the day, make it run with high velocities (in terms of km/s). I already tried to reduce the pressure tolerance and the drag model residual, but nothing satisfying. Does anybody know what can I do or what is wrong with my case ? Thanks ! |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 07:09 |
multiphaseEulerFoam (OF2.3.0) : Courant number explodes when running in parallel | Mehrez | OpenFOAM Running, Solving & CFD | 10 | May 18, 2016 12:44 |
Stuck in a Rut- interDyMFoam! | xoitx | OpenFOAM Running, Solving & CFD | 14 | March 25, 2016 08:09 |
[blockMesh] non-orthogonal faces and incorrect orientation? | nennbs | OpenFOAM Meshing & Mesh Conversion | 7 | April 17, 2013 06:42 |
the Eulerian model and the lower volume fraction | hx li | FLUENT | 2 | October 27, 2005 07:17 |
