U-shaped multiphase flow
Old   March 15, 2021, 14:52
Default U-shaped multiphase flow
Victor Vilceanu
VictorV66 is on a distinguished road
I was running an interFoam (PIMPLE) case of a U-shaped container partially filled with water, under external excitation. Since I am targeting the wall pressure/forces I am interested in the dynamic part, however it seems that this case doesn't move the water along the vertical columns (which would physically need to move back and forth), rather just sloshing horizontally.
I would be interested in capturing the movement of the water along vertical columns. Any hints/suggestions of what I would need to modify for this case to account for that as well?
I attached some random snapshots in time, for checking on what I am discussing about. The external excitation is a harmonic one.
Thank you!
VictorV66 is offline   Reply With Quote
multiphase flow adjoint solver ThibautDalemans FLUENT 0 December 18, 2019 04:51
About Some Concepts:Laminar flow, turbulent flow, steady flow and time-dependent flow Jing Main CFD Forum 8 October 5, 2018 18:02
multiphase flow ,mass and volume fraction imbalance sope111 CFX 16 September 3, 2018 01:10
Review: Reversed flow CRT FLUENT 1 May 7, 2018 06:36
Multiphase flow in a pipe with a CHT wissal CFX 4 June 12, 2017 13:15
