ship is sinking and then after sometime error is comming.Please help
Old   March 15, 2021, 08:27
Unhappy ship is sinking and then after sometime error is comming.Please help
Deutschland
vava10 is on a distinguished road
Hey,
I trying to simulate a kayak. I use dynamic mesh to get the trim and sinkage
when I run the case set up first I get really big forces of order e24 and then tít crashes with the following error
[0] [2] [3] #0  #0  Foam::error::printStack(Foam::Ostream&)#0  Foam::error::printStack(Foam::Ostream&)Foam::error::printStack(Foam::Ostream&) at ??:?
[2] #1  Foam::sigFpe::sigHandler(int) at ??:?
 at ??:?
[0] #1  Foam::sigFpe::sigHandler(int)[3] #1  Foam::sigFpe::sigHandler(int) at ??:?
[3] #2  ? at ??:?
[2] #2  ? at ??:?
[0] #2  ? in /lib/x86_64-linux-gnu/libpthread.so.0
[2] #3  Foam::GAMGSolver::scale(Foam::Field<double>&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, unsigned char) const[3] #3  Foam::GAMGSolver::scale(Foam::Field<double>&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, unsigned char) const in /lib/x86_64-linux-gnu/libpthread.so.0
[0] #3  Foam::GAMGSolver::scale(Foam::Field<double>&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, unsigned char) const at ??:?
[2] #4  Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMatrix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const at ??:?
[3] #4  Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMatrix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const at ??:?
[2] #5  Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
[0] #4  Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMatrix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const at ??:?
 at ??:?
[3] #5  Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const[2] #6  Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&) at ??:?
[0] #5  Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
[3] #6  Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&) at ??:?
 at ??:?
[0] #6  Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&)[2] #7  Foam::fvMatrix<double>::solveSegregatedOrCoupled(Foam::dictionary const&) at ??:?
 at ??:?
[2] #8  Foam::fvMesh::solve(Foam::fvMatrix<double>&, Foam::dictionary const&) const[3] #7  Foam::fvMatrix<double>::solveSegregatedOrCoupled(Foam::dictionary const&) at ??:?
[0] #7  Foam::fvMatrix<double>::solveSegregatedOrCoupled(Foam::dictionary const&) at ??:?
[3] #8  Foam::fvMesh::solve(Foam::fvMatrix<double>&, Foam::dictionary const&) const at ??:?
[2] #9  ? at ??:?
[0] #8  Foam::fvMesh::solve(Foam::fvMatrix<double>&, Foam::dictionary const&) const in /usr/lib/openfoam/openfoam2012/platforms/linux64GccDPInt32Opt/bin/interFoam
[2] #10  ? in /usr/lib/openfoam/openfoam2012/platforms/linux64GccDPInt32Opt/bin/interFoam
[2] #11  __libc_start_main at ??:?
[3] #9  ? in /lib/x86_64-linux-gnu/libc.so.6
[2] #12  ? in /usr/lib/openfoam/openfoam2012/platforms/linux64GccDPInt32Opt/bin/interFoam
[3] #10   in /usr/lib/openfoam/openfoam2012/platforms/linux64GccDPInt32Opt/bin/interFoam
[ubuntu:05707] *** Process received signal ***
[ubuntu:05707] Signal: Floating point exception (8)
[ubuntu:05707] Signal code:  (-6)
[ubuntu:05707] Failing at address: 0x3e80000164b
 at ??:?
[0] #9  [ubuntu:05707] [ 0] /lib/x86_64-linux-gnu/libpthread.so.0(+0x153c0)[0x7fe3044ff3c0]
[ubuntu:05707] [ 1] /lib/x86_64-linux-gnu/libpthread.so.0(raise+0xcb)[0x7fe3044ff24b]
[ubuntu:05707] [ 2] /lib/x86_64-linux-gnu/libpthread.so.0(+0x153c0)[0x7fe3044ff3c0]
[ubuntu:05707] [ 3] ?/usr/lib/openfoam/openfoam2012/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam10GAMGSolver5scaleERNS_5FieldIdEES3_RKNS_9lduMatrixERKNS_10FieldFieldIS1_dEERKNS_8UPtrListIKNS_17lduInterfaceFieldEEERKS2_h+0xfa)[0x7fe304f1291a]
[ubuntu:05707] [ 4] /usr/lib/openfoam/openfoam2012/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam10GAMGSolver6VcycleERKNS_7PtrListINS_9lduMatrix8smootherEEERNS_5FieldIdEERKS8_S9_S9_S9_S9_S9_RNS1_IS8_EESD_h+0x972)[0x7fe304f14732]
[ubuntu:05707] [ 5] /usr/lib/openfoam/openfoam2012/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam10GAMGSolver5solveERNS_5FieldIdEERKS2_h+0x62d)[0x7fe304f1693d]
[ubuntu:05707] [ 6] ?/usr/lib/openfoam/openfoam2012/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZN4Foam8fvMatrixIdE15solveSegregatedERKNS_10dictionaryE+0x191)[0x7fe307fd4321]
[ubuntu:05707] [ 7] /usr/lib/openfoam/openfoam2012/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZN4Foam8fvMatrixIdE24solveSegregatedOrCoupledERKNS_10dictionaryE+0x413)[0x7fe3077dbbb3]
[ubuntu:05707] [ 8] /usr/lib/openfoam/openfoam2012/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZNK4Foam6fvMesh5solveERNS_8fvMatrixIdEERKNS_10dictionaryE+0x28)[0x7fe307776eb8]
[ubuntu:05707] [ 9] interFoam(+0x11a83b)[0x55fbc99b583b]
[ubuntu:05707] [10] interFoam(+0x59d7c)[0x55fbc98f4d7c]
[ubuntu:05707] [11] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf3)[0x7fe30431f0b3]
[ubuntu:05707] [12] interFoam(+0x5d25e)[0x55fbc98f825e]
[ubuntu:05707] *** End of error message ***
[0] #10   in /usr/lib/openfoam/openfoam2012/platforms/linux64GccDPInt32Opt/bin/interFoam
[3] #11  __libc_start_main? in /lib/x86_64-linux-gnu/libc.so.6
[3] #12   in /usr/lib/openfoam/openfoam2012/platforms/linux64GccDPInt32Opt/bin/interFoam
[0] #11  __libc_start_main? in /lib/x86_64-linux-gnu/libc.so.6
[0] #12  ? in /usr/lib/openfoam/openfoam2012/platforms/linux64GccDPInt32Opt/bin/interFoam
[ubuntu:05705] *** Process received signal ***
[ubuntu:05705] Signal: Floating point exception (8)
[ubuntu:05705] Signal code:  (-6)
[ubuntu:05705] Failing at address: 0x3e800001649
[ubuntu:05705] [ 0] /lib/x86_64-linux-gnu/libpthread.so.0(+0x153c0)[0x7f38b6fb43c0]
[ubuntu:05705] [ 1] /lib/x86_64-linux-gnu/libpthread.so.0(raise+0xcb)[0x7f38b6fb424b]
[ubuntu:05705] [ 2] /lib/x86_64-linux-gnu/libpthread.so.0(+0x153c0)[0x7f38b6fb43c0]
[ubuntu:05705] [ 3] /usr/lib/openfoam/openfoam2012/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam10GAMGSolver5scaleERNS_5FieldIdEES3_RKNS_9lduMatrixERKNS_10FieldFieldIS1_dEERKNS_8UPtrListIKNS_17lduInterfaceFieldEEERKS2_h+0xfa)[0x7f38b79c791a]
[ubuntu:05705] [ 4] /usr/lib/openfoam/openfoam2012/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam10GAMGSolver6VcycleERKNS_7PtrListINS_9lduMatrix8smootherEEERNS_5FieldIdEERKS8_S9_S9_S9_S9_S9_RNS1_IS8_EESD_h+0x972)[0x7f38b79c9732]
[ubuntu:05705] [ 5] /usr/lib/openfoam/openfoam2012/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam10GAMGSolver5solveERNS_5FieldIdEERKS2_h+0x62d)[0x7f38b79cb93d]
[ubuntu:05705] [ 6] /usr/lib/openfoam/openfoam2012/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZN4Foam8fvMatrixIdE15solveSegregatedERKNS_10dictionaryE+0x191)[0x7f38baa89321]
[ubuntu:05705] [ 7] /usr/lib/openfoam/openfoam2012/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZN4Foam8fvMatrixIdE24solveSegregatedOrCoupledERKNS_10dictionaryE+0x413)[0x7f38ba290bb3]
[ubuntu:05705] [ 8]  in /usr/lib/openfoam/openfoam2012/platforms/linux64GccDPInt32Opt/bin/interFoam
[ubuntu:05708] *** Process received signal ***
[ubuntu:05708] Signal: Floating point exception (8)
[ubuntu:05708] Signal code:  (-6)
[ubuntu:05708] Failing at address: 0x3e80000164c
[ubuntu:05708] [ 0] /lib/x86_64-linux-gnu/libpthread.so.0(+0x153c0)[0x7f7a612973c0]
[ubuntu:05708] [ 1] /lib/x86_64-linux-gnu/libpthread.so.0(raise+0xcb)[0x7f7a6129724b]
[ubuntu:05708] [ 2] /lib/x86_64-linux-gnu/libpthread.so.0(+0x153c0)[0x7f7a612973c0]
[ubuntu:05708] [ 3] /usr/lib/openfoam/openfoam2012/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam10GAMGSolver5scaleERNS_5FieldIdEES3_RKNS_9lduMatrixERKNS_10FieldFieldIS1_dEERKNS_8UPtrListIKNS_17lduInterfaceFieldEEERKS2_h+0xfa)[0x7f7a61caa91a]
[ubuntu:05708] [ 4] /usr/lib/openfoam/openfoam2012/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam10GAMGSolver6VcycleERKNS_7PtrListINS_9lduMatrix8smootherEEERNS_5FieldIdEERKS8_S9_S9_S9_S9_S9_RNS1_IS8_EESD_h+0x972)[0x7f7a61cac732]
[ubuntu:05708] [ 5] /usr/lib/openfoam/openfoam2012/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam10GAMGSolver5solveERNS_5FieldIdEERKS2_h+0x62d)[0x7f7a61cae93d]
[ubuntu:05708] [ 6] /usr/lib/openfoam/openfoam2012/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZN4Foam8fvMatrixIdE15solveSegregatedERKNS_10dictionaryE+0x191)[0x7f7a64d6c321]
[ubuntu:05708] [ 7] /usr/lib/openfoam/openfoam2012/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZN4Foam8fvMatrixIdE24solveSegregatedOrCoupledERKNS_10dictionaryE+0x413)[0x7f7a64573bb3]
[ubuntu:05708] [ 8] /usr/lib/openfoam/openfoam2012/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZNK4Foam6fvMesh5solveERNS_8fvMatrixIdEERKNS_10dictionaryE+0x28)[0x7f7a6450eeb8]
[ubuntu:05708] [ 9] interFoam(+0x11a83b)[0x55f7ec62f83b]
[ubuntu:05708] [10] interFoam(+0x59d7c)[0x55f7ec56ed7c]
[ubuntu:05708] [11] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf3)[0x7f7a610b70b3]
[ubuntu:05708] [12] interFoam(+0x5d25e)[0x55f7ec57225e]
[ubuntu:05708] *** End of error message ***
/usr/lib/openfoam/openfoam2012/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZNK4Foam6fvMesh5solveERNS_8fvMatrixIdEERKNS_10dictionaryE+0x28)[0x7f38ba22beb8]
[ubuntu:05705] [ 9] interFoam(+0x11a83b)[0x55b053f2583b]
[ubuntu:05705] [10] interFoam(+0x59d7c)[0x55b053e64d7c]
[ubuntu:05705] [11] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf3)[0x7f38b6dd40b3]
[ubuntu:05705] [12] interFoam(+0x5d25e)[0x55b053e6825e]
[ubuntu:05705] *** End of error message ***
Primary job  terminated normally, but 1 process returned
a non-zero exit code. Per user-direction, the job has been aborted.
mpirun noticed that process rank 0 with PID 0 on node ubuntu exited on signal 8 (Floating point exception).
kayak length 5.19m
weight 77kg
width 0.4 depth 0.2
velocity 5.5
domain sixze 21*3.6*13.2
dynamicMeshDict
|  \\    /   O peration     | Version:  v2012                                 |
|   \\  /    A nd           | Website:  www.openfoam.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      dynamicMeshDict;
dynamicFvMesh   dynamicMotionSolverFvMesh;
motionSolverLibs ("libsixDoFRigidBodyMotion.so");
motionSolver    sixDoFRigidBodyMotion;
patches         (hull);
innerDistance   0.3;
outerDistance   1;
centreOfMass    (-2.63034697966 0.0 0.0244732718937);
mass            38.5;
momentOfInertia (0.222320255589 41.6518680701 41.5667249019);
rhoInf          1;
report          on;
value           uniform (0 0 0);
accelerationRelaxation 0.4;
solver
    type Newmark;
ramp
    type     quadraticRamp;//this
    start    0;
    duration 10;
constraints
    zAxis
        sixDoFRigidBodyMotionConstraint line;
        direction     (0 0 1);
    yPlane
        sixDoFRigidBodyMotionConstraint axis;
        axis          (0 1 0);
restraints
    translationDamper
        sixDoFRigidBodyMotionRestraint linearDamper;
        coeff         8596;
    rotationDamper
        sixDoFRigidBodyMotionRestraint sphericalAngularDamper;
        coeff         11586;
controlDict
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      controlDict;
application     interFoam;
startFrom       startTime;
startTime       0;
stopAt          endTime;
endTime         5;
deltaT          0.0001;
writeControl    adjustable;
writeInterval   1;
purgeWrite      0;
writeFormat     binary;
writePrecision  6;
writeCompression off;
timeFormat      general;
timePrecision   6;
runTimeModifiable yes;
adjustTimeStep  yes;
maxCo           0.95;
maxAlphaCo      0.95;
maxDeltaT       0.1;
functions
    forces
        type            forces;
        libs            ("libforces.so");
        patches         (hull);
        rhoInf          1000.0;
        log             on;
        writeControl    timeStep;
        writeInterval   2;
        CofR            (-2.4453 0 0.1155);
    yPlus
        type            yPlus;
        libs            ("libfieldFunctionObjects.so");
        writeControl    writeTime;
        patches         (hull);
fvSchrme
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSchemes;
ddtSchemes
    default         Euler;
gradSchemes
    default         Gauss linear;
divSchemes
    div(rhoPhi,U)   Gauss linearUpwind grad(U);
    div(phi,alpha)  Gauss vanLeer;
    div(phirb,alpha) Gauss linear;
    div(phi,k)      Gauss linearUpwind limitedGrad;
    div(phi,omega)  Gauss linearUpwind limitedGrad;
    div(((rho*nuEff)*dev2(T(grad(U))))) Gauss linear;
laplacianSchemes
    default         Gauss linear corrected;
interpolationSchemes
    default         linear;
snGradSchemes
    default         corrected;
wallDist
    method meshWave;
fvSolution
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSolution;
solvers
    "alpha.water.*"
        nAlphaCorr      3;
        nAlphaSubCycles 1;
        cAlpha          1;
        icAlpha         0;
        MULESCorr       yes;
        nLimiterIter    15;
        alphaApplyPrevCorr  yes;
        solver          smoothSolver;
        smoother        symGaussSeidel;
        tolerance       1e-10;
        relTol          0;
        minIter         1;
    "pcorr.*"
        solver          GAMG;
        smoother        DIC;
        tolerance       1e-3;
        relTol          0;
    p_rgh
        solver          GAMG;
        smoother        DIC;
        tolerance       5e-8;
        relTol          0;
    p_rghFinal
        $p_rgh;
        relTol          0;
    "(U|k|omega).*"
        nSweeps         1;
        tolerance       1e-7;
        relTol          0;
        minIter         1;
PIMPLE
    momentumPredictor no;
    nOuterCorrectors 2;
    nCorrectors      2;
    nNonOrthogonalCorrectors 0;
    correctPhi      yes;
    moveMeshOuterCorrectors yes;
    turbOnFinalIterOnly yes;
 residualControl
        p_rgh
            tolerance 1e-04;//this
            relTol 0;
            absTol 0;
relaxationFactors
    equations
        ".*" 1;
cache
    grad(U);
k =0.0159
omega =55.634
nu =2.85e-4
I have attached the graph i got still before it crashed. I have to submit it within 2 weeks. I am completely stuck. I am not an expert in CFD or fluid dynamics Please HelpThis is when I ran the simulation in i5
vava10 is offline   Reply With Quote
Old   March 15, 2021, 08:34
Default Hpc
Deutschland
The following is the log file while running it in the HPC. From that day when looking at the position of center of mass it can be seen it is sinking
Restraint translationDamper:  force (-0 -0 -3.49197e+10)
Restraint rotationDamper:  moment (-0 2.28919e+11 -0)
6-DoF rigid body motion
    Centre of rotation: (-2.63035 0.061775 0.0244009)
    Centre of mass: (-2.63035 0.061775 0.0244009)
    Orientation: (1 0 0.000286163 0 1 0 -0.000286163 0 1)
    Linear velocity: (0 0 -1.21972e+07)
    Angular velocity: (0 5.93616e+07 0)
GAMG:  Solving for pcorr, Initial residual = 1, Final residual = 0.000799427, No Iterations 14
time step continuity errors : sum local = 3.71117e-08, global = 1.31116e-08, cumulative = 1.35688e-08
smoothSolver:  Solving for alpha.water, Initial residual = 8.6874e-06, Final residual = 6.00772e-12, No Iterations 3
Phase-1 volume fraction = 0.59093  Min(alpha.water) = -1.44368e-27  Max(alpha.water) = 1.00213
Applying the previous iteration compression flux
MULES: Correcting alpha.water
Phase-1 volume fraction = 0.59093  Min(alpha.water) = -1.0006e-11  Max(alpha.water) = 1.00213
GAMG:  Solving for p_rgh, Initial residual = 0.00791133, Final residual = 4.1851e-08, No Iterations 21
time step continuity errors : sum local = 2.47328e-10, global = 5.03656e-11, cumulative = 1.36192e-08
GAMG:  Solving for p_rgh, Initial residual = 0.544529, Final residual = 4.5177e-08, No Iterations 27
time step continuity errors : sum local = 7.1092e-10, global = -1.39258e-10, cumulative = 1.34799e-08
smoothSolver:  Solving for omega, Initial residual = 0.179014, Final residual = 4.30555e-08, No Iterations 5
bounding omega, min: -579.251 max: 64622.9 average: 982.172
smoothSolver:  Solving for k, Initial residual = 2.5363e-05, Final residual = 9.14855e-08, No Iterations 4
bounding k, min: -0.0139333 max: 0.618031 average: 0.0198725
PIMPLE: not converged within 2 iterations
ExecutionTime = 146.72 s  ClockTime = 148 s
forces forces write:
    Sum of forces
        Total    : (2.37239e+20 -2.11363e+22 3.49298e+22)
        Pressure : (2.37239e+20 -2.11363e+22 3.49298e+22)
        Viscous  : (3.93514e+07 6.46864e+09 8.6976e+09)
    Sum of moments
        Total    : (-1.88927e+21 -1.66852e+23 -1.01792e+23)
        Pressure : (-1.88927e+21 -1.66852e+23 -1.01792e+23)
        Viscous  : (1.94829e+09 -4.16082e+10 3.02513e+10)
Courant Number mean: 0.190354 max: 33.2753
Interface Courant Number mean: 8.46451e-05 max: 13.2657
deltaT = 1.29125e-13
Time = 0.000587577
PIMPLE: iteration 1
forces forces:
    rho: rho
    Not including porosity effects
Restraint translationDamper:  force (-0 -0 1.04847e+11)
Restraint rotationDamper:  moment (-0 -6.87764e+11 -0)
    Centre of rotation: (-2.63035 0.061775 0.0244007)
    Centre of mass: (-2.63035 0.061775 0.0244007)
    Orientation: (1 0 0.000287181 0 1 0 -0.000287181 0 1)
    Linear velocity: (0 0 1.03099e+07)
    Angular velocity: (-0 -4.35927e+07 0)
GAMG:  Solving for pcorr, Initial residual = 1, Final residual = 0.000802417, No Iterations 15
time step continuity errors : sum local = 2.46298, global = 1.01538, cumulative = 1.01538
smoothSolver:  Solving for alpha.water, Initial residual = 0.217255, Final residual = 8.19276e-11, No Iterations 81
Phase-1 volume fraction = 0.353779  Min(alpha.water) = -2.57833e-25  Max(alpha.water) = 1.00008
Phase-1 volume fraction = 109504  Min(alpha.water) = -5.24675e+13  Max(alpha.water) = 2.6115e+13
GAMG:  Solving for p_rgh, Initial residual = 1, Final residual = 3.57815e-08, No Iterations 33
time step continuity errors : sum local = 0.00013694, global = 3.58262e-05, cumulative = 1.01542
GAMG:  Solving for p_rgh, Initial residual = 0.0150425, Final residual = 3.87443e-08, No Iterations 24
time step continuity errors : sum local = 0.0535639, global = -0.00531016, cumulative = 1.01011
PIMPLE: iteration 2
forces forces:
    rho: rho
Restraint translationDamper:  force (-0 -0 -8.86236e+10)
Restraint rotationDamper:  moment (0 5.05065e+11 -0)
    Centre of rotation: (-2.63035 0.061775 -2.54297e+07)
    Centre of mass: (-2.63035 0.061775 -2.54297e+07)
    Orientation: (0.884944 0 0.465697 0 1 0 -0.465697 0 0.884944)
    Linear velocity: (0 0 -3.93877e+20)
    Angular velocity: (0 1.45696e+21 0)
