rhoCentralFoam cannot run with moderate Co numbers |
March 12, 2021, 04:06 |
Rep Power: 7 |
Hello everyone,
I am doing verification work with plat plate which is meshed with hexa meshs. 0.3Ma and 100k Re number is flow conditions. Here is the checkMesh output: Code:
Create time Create mesh for time = 0 Time = 0 Mesh stats points: 108559 faces: 301540 internal faces: 278060 cells: 96600 faces per cell: 6 boundary patches: 7 point zones: 0 face zones: 1 cell zones: 1 Overall number of cells of each type: hexahedra: 96600 prisms: 0 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 0 polyhedra: 0 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology bc-2 920 1023 ok (non-closed singly connected) bc-6 1380 1529 ok (non-closed singly connected) bc-8 700 781 ok (non-closed singly connected) bc-3 460 517 ok (non-closed singly connected) bc-4 9660 9869 ok (non-closed singly connected) bc-5 9660 9869 ok (non-closed singly connected) bc-7 700 781 ok (non-closed singly connected) Checking faceZone topology for multiply connected surfaces... FaceZone Faces Points Surface topology interior-unspecified278060 108551 multiply connected (shared edge) <<Writing 107691 conflicting points to set nonManifoldPoints Checking basic cellZone addressing... CellZone Cells Points Volume BoundingBox unspecified 96600 108559 0.375 (-1 0 0) (2 0.25 0.5) Checking geometry... Overall domain bounding box (-1 0 0) (2 0.25 0.5) Mesh has 3 geometric (non-empty/wedge) directions (1 1 1) Mesh has 3 solution (non-empty) directions (1 1 1) Boundary openness (7.58991e-17 -7.5588e-16 2.59421e-16) OK. ***High aspect ratio cells found, Max aspect ratio: 8333.33, number of cells 18850 <<Writing 18850 cells with high aspect ratio to set highAspectRatioCells Minimum face area = 5e-09. Maximum face area = 0.00529875. Face area magnitudes OK. Min volume = 1.25e-10. Max volume = 0.000132469. Total volume = 0.375. Cell volumes OK. Mesh non-orthogonality Max: 0 average: 0 Non-orthogonality check OK. Face pyramids OK. Max skewness = 2.13164e-14 OK. Coupled point location match (average 0) OK. Failed 1 mesh checks. End Bc-6 and bc-8 are pressure outlet, and bc-7 is velocity inlet. Bc-2 is plate wall and the rests are symmetry bcs. Here are case settings : Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2006 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volVectorField; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (104.1634 0 0); boundaryField { bc-6 { type zeroGradient; } bc-8 { type zeroGradient; } bc-7 { type fixedValue; value $internalField; } bc-3 { type symmetryPlane; } bc-4 { type symmetryPlane; } bc-5 { type symmetryPlane; } bc-2 { type noSlip; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2006 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; object T; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 0 0 1 0 0 0]; internalField uniform 300; boundaryField { bc-6 { type zeroGradient; } bc-8 { type zeroGradient; } bc-7 { type fixedValue; value $internalField; } bc-3 { type symmetryPlane; } bc-4 { type symmetryPlane; } bc-5 { type symmetryPlane; } bc-2 { type zeroGradient; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2006 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; object p; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [1 -1 -2 0 0 0 0]; internalField uniform 1479.288; boundaryField { bc-6 { type totalPressure; p0 $internalField; } bc-8 { type totalPressure; p0 $internalField; } bc-7 { type zeroGradient; } bc-3 { type symmetryPlane; } bc-4 { type symmetryPlane; } bc-5 { type symmetryPlane; } bc-2 { type zeroGradient; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v1812 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvSchemes; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // fluxScheme Kurganov; ddtSchemes { default CrankNicolson 0.8; //Euler; //ddt(phi) CrankNicolson 1.0; } gradSchemes { default cellLimited Gauss linear 1.0; } divSchemes { default none; div(tauMC) Gauss linear; ///Gauss linear; } laplacianSchemes { default Gauss linear corrected ; } interpolationSchemes { default linear; reconstruct(rho) vanLeer; reconstruct(U) vanLeerV; reconstruct(T) vanLeer; } snGradSchemes { default corrected; } /*wallDist { method meshWave; }*/ // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v1812 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvSolution; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // solvers { "(rho|rhoU|rhoE)" { solver diagonal; } U { solver smoothSolver; smoother GaussSeidel; nSweeps 2; tolerance 1e-12; relTol 0.1; } h { $U; tolerance 1e-12; relTol 0.01; } "(U|h)Final" { $U; relTol 0; } e { solver GAMG; smoother GaussSeidel; tolerance 1e-12; relTol 0.1; } eFinal { $e; relTol 0; } } cache { grad(U); } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v1812 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object controlDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // application rhoCentralFoam; startFrom latestTime; startTime 0; stopAt endTime; endTime 0.05; deltaT 1e-03; writeControl adjustableRunTime; writeInterval 0.001; purgeWrite 0; writeFormat ascii; writePrecision 6; writeCompression off; timeFormat general; timePrecision 6; runTimeModifiable true; adjustTimeStep yes; maxCo 0.5; maxDeltaT 0.01; Code:
Mean and max Courant Numbers = 0.00122766 0.713041 deltaT = 3.34673e-08 Time = 1.70413e-06 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rhoUx, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rhoUy, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rhoUz, Initial residual = 0, Final residual = 0, No Iterations 0 smoothSolver: Solving for Ux, Initial residual = 0.000246952, Final residual = 6.03144e-06, No Iterations 2 smoothSolver: Solving for Uy, Initial residual = 0.0022567, Final residual = 6.19651e-05, No Iterations 2 smoothSolver: Solving for Uz, Initial residual = 0.000715669, Final residual = 1.91404e-05, No Iterations 2 diagonal: Solving for rhoE, Initial residual = 0, Final residual = 0, No Iterations 0 GAMG: Solving for e, Initial residual = 0.00237767, Final residual = 5.07603e-05, No Iterations 1 --> FOAM FATAL ERROR: Negative initial temperature T0: -1501.71 From Foam::scalar Foam::species::thermo<Thermo, Type>::T(Foam::scalar, Foam::scalar, Foam::scalar, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar, Foam::scalar) const, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar, Foam::scalar) const, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar) const) const [with Thermo = Foam::hConstThermo<Foam::perfectGas<Foam::specie> >; Type = Foam::sensibleInternalEnergy; Foam::scalar = double; Foam::species::thermo<Thermo, Type> = Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy>] in file /opt/apps/OpenFOAM/OpenFOAM-v2006/src/thermophysicalModels/specie/lnInclude/thermoI.H at line 56. FOAM aborting #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::error::exitOrAbort(int, bool) at ??:? #2 Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::constTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy> > > >::calculate(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, bool) at ??:? #3 Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::constTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy> > > >::correct() at ??:? #4 ? at ??:? #5 __libc_start_main in /usr/lib64/libc.so.6 #6 ? at ??:? Thanks for any advice. |
March 18, 2021, 02:44 |
Rep Power: 7 |
Really? No one has any idea ?
March 23, 2021, 05:41 |
Rep Power: 8 |
The reason why Ansys works is probably, that it goes back to first order schemes when it notices divergence. You dont have that in OpenFoam.
You are trying second order schemes with high courant numbers. That usually doesnt work well, because naturally high order schemes impose oscillations in your simulaitons. Thats why those limiters like vanLeer were invented. If you want high Co-Numbers you should use Minmod instead of vanLeer. But Minmod is not truly second order. If you still want vanLeer you can use the limitTemperature functionality. Your BCs might be also wrong, -1500K is quite a heavy result. Also your mesh is not good. |
March 24, 2021, 03:54 |
#4 | |
Rep Power: 7 |
Why does the mesh is not good? Can you explain more? It is fully up Hexas, with very fine BL. It is normal to have high aspect ratio, dont you agree ? I tried minmod,vanLeer,upwing, nothing has changed |
March 24, 2021, 05:27 |
Rep Power: 8 |
As soon as you start your simulation, in the first few lines of the log, there should a message appear that states that fvOption with the limiter functionality has been chosen. If there is no such message or an error occured, you dont use this functionality.
As I said, rhoCentralFoam hasnt this functionality, if you didnt have implemented it yourself, its not working. |
March 24, 2021, 07:58 |
#6 | |
Rep Power: 7 |
Although i can choose higher Co numbers now, when it is crashed, it gives Negative initial temp T0: -497 again. Because it starts to exceed max Co limit now. Normally it should not exceed max Co limit, because time step is adjusted. DO you have any idea why it gives this error? |
March 24, 2021, 08:21 |
Rep Power: 8 |
Besides wrong BCs, what you should definitly check, my best practice suggestions would be:
1. vanAlbada instead of vanLeer limit, which is less oscillary 2. Co = 0.2 or better 0.1 if possible 3. check your thermophysical properties, especially their units 4. first run laminar, then add a turbulence model 5. dont use GAMG, I have bad experiences with that. Also use relTol 0. This is the fvSchemes dict from one of my cases: Code:
solvers { "rho.*" { solver diagonal; } "U.*" { solver smoothSolver; smoother GaussSeidel; nSweeps 2; tolerance 1e-9; relTol 0.0; } e { $U; tolerance 1e-9; relTol 0.00; } h { $U; tolerance 1e-9; relTol 0.00; } "(k|omega|epsilon|f|v2)" { solver smoothSolver; smoother symGaussSeidel; tolerance 1e-09; nSweeps 2; relTol 0.0; } } |
March 25, 2021, 02:02 |
Rep Power: 7 |
Thanks for your helps. I tried most of your suggestions. However, it seems no possibility for increase without changing BCs.
I am doing verification case of a laminar flat plate which is exposed to 0.3-10k Re and 0.87-100kRe Mach flows. I am comparing dimensionless Rho and dimensionless T in boundary layer with analytical results. The BL thichness with rhoCentralFoam is larger than it supposed to be. I tried to increase CFL number first by thinking case is not converged. However, i run it for long time, and results are not changed. So, i am sure that it converged. There is 2 possibility: BCs or Unconformity of solver. I should add, i am also making analysis with rhoPimpleFoam. This solver predicts velocity profile correct but T and Rho dont have correct profiles. On the contrary, RhocentralFoam predicts T and Rho but velocity profile is not correct. Something about Bc must be wrong. As it can be seen in my first post, named patchs as bc-2 wall, bc-3/bc-4/bc-5 sym, bc-6/bc-8 pressure outlet, bc-7 pressure inlet. What would you suggest as boundary conditions for my case? |
March 25, 2021, 06:18 |
#9 |
Rep Power: 8 |
I rechecked your BCs and might have found the error. For supersonic flow you usually use at the Inlet fixedValue for u,T and p. For the outlet I mostly use waveTransmissive for u and p and zeroGradient for T, but my cases have a lot of shocks and shock interactions. Still you should try that.
If you want to use totalPressure (depending what you know about your flow from measurements etc.), you should use totalPressure, totalTemperature, pressureInletOutletVelocity at the inlet and waveTransmissive and zeroGradient at the outlet. Hope it helps. |
March 25, 2021, 07:38 |
#10 | |
Rep Power: 7 |
In ansys fluent, you can define operating pressure or gauge pressure. For incompressible flows, P_g is zero assumed and P_ope is defined. For compressible is the opposite of that. If i define P_ope as 104 Kpa in fluent, what should i define the pressure in Openfoam ? |
March 25, 2021, 10:16 |
#11 |
Rep Power: 8 |
I cant help you with ansys since I dont work with that.
You can find all BCs just by googling it and by looking into the documentation of openfoam. e.g. Code:
waveTransmissive type waveTransmissive; gamma 1.4; fieldInf 101325; lInf 1; value uniform 101325; or totalPressure type totalPressure; rho none; psi thermo:psi; gamma 1.4; p0 uniform 2e5; value uniform 2e5; |
Problem in foam-extend 4.0 ggi parallel run | Metikurke | OpenFOAM Running, Solving & CFD | 0 | February 20, 2018 07:34 |
parallel run is slower than serial run (pimpleFoam) !!! | mechy | OpenFOAM | 18 | August 17, 2016 18:19 |
Slow run with rhoCentralFoam | yash.aesi | OpenFOAM Running, Solving & CFD | 20 | June 15, 2015 08:16 |
Can not run OpenFOAM in parallel in clusters, help! | ripperjack | OpenFOAM Running, Solving & CFD | 5 | May 6, 2014 16:25 |
HELP!! Prandtl numbers in RNG k-e turbulence model | maoasis | FLUENT | 0 | April 24, 2006 11:51 |
