Setting origProcID by using a solidParticleInterFoam-solver
Old   March 11, 2021, 08:15
Default Setting origProcID by using a solidParticleInterFoam-solver
Sarah Falk
sarah37 is on a distinguished road
Hi everyone,
I try to implement a solidParticleInterFoam-Solver by using this tutorial: http://www.tfd.chalmers.se/~hani/kur...iclesInVOF.pdf .
Now I want to simulate the (solid)damBreak as it is described in the tutorial, but I'm getting the following error-message and don't know how to fix the problem:
--> FOAM FATAL ERROR:
Size of origProcId field 0 does not match the number of particles 2
From function void Foam::Cloud<ParticleType>::checkFieldIOobject(cons t Foam::Cloud<ParticleType>&, const Foam::IOField<DataType>&) const [with DataType = int; ParticleType = Foam::solidParticle]
in file /home/ubuntu/OpenFOAM/OpenFOAM-6/src/lagrangian/basic/lnInclude/CloudIO.C at line 191.
FOAM aborting
My "origProcID"-File looks like that:
| \\ / O peration | Version: v1806 |
| \\ / A nd | Web: www.OpenFOAM.com |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class labelField;
location "0/lagrangian/defaultCloud";
object origProcID;
2(0)
I have noticed, that the error-message doens't change, when I write an other number instead of 0. I also tried two numbers or other brackets. So I think, that origProcID-field is not setting correctly, but I have no idea, how I can checkt or change it.
Have one of you any idea how I can fix my problem? I am thankfull for any kind of help!
sarah37 is offline   Reply With Quote
origprocid, solidparticlecloud, solidparticlefoam
fluent solver setting for external aerodynamics on a race car. Ahmed Jamal FLUENT 5 March 26, 2016 04:13
Interfoam blows on parallel run danvica OpenFOAM Running, Solving & CFD 16 December 22, 2012 03:09
Quarter Burner mesh with periosic condition SamCanuck FLUENT 2 August 31, 2011 12:34
Working directory via command line Luiz CFX 4 March 6, 2011 21:02
why the solver reject it? Anyone with experience? bearcat CFX 6 April 28, 2008 15:08
