ScalarTransportFoam for RTD calculations for laminar non-Newtonian flow
Old   March 11, 2021, 04:33
Default ScalarTransportFoam for RTD calculations for laminar non-Newtonian flow
Sourav Mandal
sourav90 is on a distinguished road
Hello foamers,
I am interested in getting residence time distribution for a relatively easy case: a 20m long pipe with 12.5mm diameter, modelled as axisymmetric wedge. I am following the method described here: ScalarTransportFoam for RTD calculations
i.e. running simpleFoam to get steady state velocity field (The transport model is powerLaw.) and then use it for RTD with scalarTransportFoam. However, whatever the values of DT (tried from 0.01 to 1e6), the plot of T shows only one value.
Any ideas on what could be wrong, especially since scalarTransportFoam is one of the most basic solvers in openFOAM? I can provide the case if it helps!
Thanks,
sourav90 is offline   Reply With Quote
Old   September 28, 2024, 17:04
Munaf
mwmalkawi is on a distinguished road
Hi were you able to sort out your issue because I am having something similar when I put very low DT it does not give realistic results but when I increase it significantly it gives good results so woundering if sliver scalar transport foam has issues
mwmalkawi is offline   Reply With Quote
non newtonian power law, rtd, scalartransportfoam, steady state
Gate valve flow simulations... nikesh FloEFD, FloWorks & FloTHERM 5 January 28, 2014 02:31
flow calculations with RANS 2eq models Andreas Abdon Main CFD Forum 3 March 8, 2000 07:09
Flow visualization vs. Calculated flow patterns Francisco Saldarriaga Main CFD Forum 1 August 3, 1999 00:18
Question on 3D potential flow Adrin Gharakhani Main CFD Forum 13 June 21, 1999 06:18
computation about flow around a yawed cone Tylor Xie Main CFD Forum 0 June 9, 1999 08:33
