BeamInCross interface no aligned at corner points by icoFsiElasticNonLinULSolidFoam
Old   March 9, 2021, 08:11
Question BeamInCross interface no aligned at corner points by icoFsiElasticNonLinULSolidFoam
han
oranjesr is on a distinguished road
Hi all, I am doing a FSI benchmark of the icoFsiElasticNonLinULSolidFoam solver in foam-extend 3.2, meshes is a 2D case with z direction set to empty.
The case can run good for sometime, but at certain condition, it crashes. Output the deformation of fluid and soild meshes , the reslut is strange, most fluid mesh points at interface move correctly,however, the corner points(points shared by two orthogonal faces) not aligned all the time, and finally leading to the distortion of fluid meshs.
Any one encouter similar problem?
oranjesr is offline   Reply With Quote
Old   March 19, 2021, 03:55
Exclamation
han
it seems when move the solid patch, the points of solid patch are interpolated w
using the leastsquare method from volume, but on the fluid side, i don't find out the correct source of the movement of points??????????????
icofsielastic*foam
SU2-7.0.1 on ubuntu 18.04 hyunko SU2 Installation 7 March 16, 2020 05:37
Can I achieve better convergence? sheaker CFX 12 September 19, 2019 16:36
Sliding Interface issues philippose OpenFOAM Running, Solving & CFD 7 May 5, 2014 04:13
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 08:36
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 21:09
