Implementing scalarcoded source in chtmultiregionFoam
Old   March 8, 2021, 12:46
Smile Implementing scalarcoded source in chtmultiregionFoam
Anish Pal
AnishPal is on a distinguished road
I want to implement a time varying vol. heat generation in chtmultiregionFoam. I have done so following the previous threads but my temperature is not increasing. Can anyone please help me. And sometimes while running the solver it is saying selection mode not define although i have defined it. I think the codedsource is not being properly read by the solver. I am attaching the case here as well.
AnishPal is offline   Reply With Quote
Old   March 10, 2021, 11:55
Anish Pal
Can anyone please help me?
Old   July 27, 2021, 10:22
Sergey
seregaxvm is on a distinguished road
In all examples heat source value is added to the heSource field:
heSource += 1e3*(time.value())*V;
seregaxvm is offline   Reply With Quote
Old   July 27, 2021, 17:15
Sergey
After investigation using method described in this post I've learned that additional heat source value should be negative and must be divided among mesh cells. So I came up with this line:
heSource -= (heatW / (heSource.size()));
where heatW is a heat generation rate in [W].
Make sure that heatW is a floating point variable, otherwise you'll get rounded integer division.
Old   July 27, 2021, 17:38
trailer is on a distinguished road
Please correct me if I am wrong, but to implement a source term with fvOptions I think you should have the following:
const scalarField& V = mesh_.V();
scalarField& S = eqn.source();
forAll(S, cellI)
     // Calculation of your source term for each cell in the domain
     mySourceTermForCelllI = Something
     S[cellI] = -V[cellI] * mySourceTermForCelllI;
Additionally, do you know why the fvOptions dictionary is sometimes found on constant folder and other times on the system folder?
OpenFOAM documentation says that the file can "live" in both folders [https://www.openfoam.com/documentati...voptions.html]. This must be one of the only dictionaries with this type of flexibility ...
trailer is offline   Reply With Quote
Old   July 27, 2021, 17:53
Sergey
Yes, I've skipped boilerplate code. Additionally, mesh_.V() is a cell volume list. You'll need it only if you define your heat source in [W/m^3] units.
Old   July 27, 2021, 19:02
Sorry if this is too basic, but do you know the reason why I am multiplying by the cell volume and the heat source is being given in [W/m^3].
Old   July 28, 2021, 04:57
Sergey
One other note. codedSourse doesn't seem to work when limitTemperature is on.
Sorry, didn't understand the question.
chtmultiregionfoam, scalarcodedsource
[OpenFOAM.com] swak4foam compiling issues on a cluster saj216 OpenFOAM Installation 5 January 17, 2023 17:05
polynomial BC srv537 OpenFOAM Pre-Processing 4 December 3, 2016 10:07
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 10:17
[swak4Foam] funkySetFields compilation error tayo OpenFOAM Community Contributions 39 December 3, 2012 06:18
friction forces icoFoam ofslcm OpenFOAM 3 April 7, 2012 11:57
