Boundary Conditions for a Wind-Tunnel Calculation
Old   March 8, 2021, 07:54
Default Boundary Conditions for a Wind-Tunnel Calculation
Alex
sepbub is on a distinguished road
Hallo together!
I'm just trying to calculate my first lager project, so maybe I've made some basic mistakes.
So my goal is to calculate an opened Windtunnel (see photo). All walls should have a boundary layer and the model is symmetric. So in my oppinion it should be ok, to calculate a quarter of the tunnel.
When using simpleFoam I'll get the following Error:
smoothSolver:  Solving for Ux, Initial residual = 1, Final residual = 15.5344, No Iterations 1000
smoothSolver:  Solving for Uy, Initial residual = 1, Final residual = 1.26609, No Iterations 1000
smoothSolver:  Solving for Uz, Initial residual = 1, Final residual = 0.44793, No Iterations 1000
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::sigFpe::sigHandler(int) at ??:?
#2  ? in "/lib/x86_64-linux-gnu/libc.so.6"
#3  Foam::GAMGSolver::scale(Foam::Field<double>&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, unsigned char) const at ??:?
#4  Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMatrix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const at ??:?
#5  Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
#6  Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&) at ??:?
#7  Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/simpleFoam"
#8  Foam::fvMatrix<double>::solve() in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/simpleFoam"
#9  ? in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/simpleFoam"
#10  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#11  ? in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/simpleFoam"
Gleitkomma-Ausnahme (Speicherabzug geschrieben)
I assume the reason for that unconvergence are wrong start conditions?!
Here are they:
U:
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (19 0 0);
boundaryField
    symmetry
        type            symmetry;
    wall
        type            fixedValue;
        value           uniform (0 0 0);
    outlet
        type            fixedValue;
        value           uniform (-8 0 0);
    inlet
        type            fixedValue;
        value           uniform (-1.2666 0 0);
//type            zeroGradient;
p:
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform 0;
boundaryField
    symmetry
        type            symmetry;
    wall
        type            zeroGradient;
    inlet
        type            fixedValue;
        value           uniform 0;
    outlet
        type            zeroGradient;
nut:
dimensions      [0 2 -1 0 0 0 0];
boundaryField
    symmetry
        type            symmetry;
    wall
        type            nutkWallFunction;
        value           uniform 0;
    inlet
        type            calculated;
        value           uniform 0;
    outlet
        type            calculated;
        value           uniform 0;
and nutTilda:
internalField   uniform 0.14;
boundaryField
    symmetry
        type            symmetry;
    wall
        type            zeroGradient;
    inlet
        type            fixedValue;
        value           uniform 0;
    outlet
        type            zeroGradient;
For the completeness my controlDict:
application     simpleFoam;
startFrom       startTime;
startTime       0;
stopAt          endTime;
endTime         100000;
deltaT          1;
writeControl    timeStep;
writeInterval   5000;
purgeWrite      0;
writeFormat     ascii;
writePrecision  6;
writeCompression off;
timeFormat      general;
timePrecision   6;
runTimeModifiable true;
For tubulence modeling I use SpalartAlmaras.
So are there obvious mistakes in my Files, or shall I have a look on some other stuff I didn't considere right now?
Thanks a lot!
(All Mesh Checks went well)
File Type: png Bildschirmfoto vom 2021-03-08 12-42-48.png (16.0 KB, 8 views)
sepbub is offline   Reply With Quote
Problem in setting Boundary Condition Madhatter92 CFX 12 January 12, 2016 05:39
Waterwheel shaped turbine inside a pipe simulation problem mshahed91 CFX 3 January 10, 2015 12:19
Difficulty In Setting Boundary Conditions Moinul Haque CFX 4 November 25, 2014 18:30
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
