PimpleFoam max CO? Problem with Fluent meshing. |
Kyfrankie
Rep Power: 5 ![]() |
Hello guys. I am trying to run a NACA wing CFD at RE100k with PimpleFoam inpiso mode. The mesh is generated by Fluent meshing and it is a poly-hexcore mesh. However, I discovered that at the corner, the BL has quite a small cell which leads to high CO there and long run time. In order to reduce the run time, can I adjust the MaxCo to 2 or more because the CO for other parts of the wing is quite small. Or is there any techniques to improve the BL cell at the corner?
WhatsApp Image 2021-03-07 at 3.01.12 PM.jpeg |
[Gmsh] gmshToFoam generates patches with 0 faces and 0 points | Simurgh | OpenFOAM Meshing & Mesh Conversion | 4 | August 25, 2023 07:58 |
multiphase turbulance case floating error | harsha_kulkarni | OpenFOAM Running, Solving & CFD | 3 | February 18, 2016 05:06 |
[Gmsh] Vertex numbering is dense | KateEisenhower | OpenFOAM Meshing & Mesh Conversion | 7 | August 3, 2015 10:49 |
Interesting problem: Parallel Processor VOF Fluent + Dynamic Mesh + System Coupling | spaceprop | FLUENT | 5 | September 2, 2014 09:43 |
[ICEM] Meshing problem from ICEM CFD to Fluent | cfdonlinederafa | ANSYS Meshing & Geometry | 2 | September 21, 2010 16:16 |
