March 4, 2021, 21:16 |
Problem with icoFoam. Simulation diverges.
Hi! I'm new using OpenFoam. I'm triying to run a case for my thesis work, but my simulation diverges.
The case is about a orifice place. The problem is that my courant number rises until values of 1e+50 (clearly diverges). I have tried changing the solver and use turbulent models like RAS or LES with solvers like pimpleFoam or simpleFoam (I have also tried to run the stationary problem). But apperantly the problem isn't in the configuration of the case. I believe that the problem is in the Mesh. So I run checkMesh but everything seems to be okey. So either the mesh is wrong or my boundary conditions are wrong. I also have tried to use relaxation factors (like 0.3 ) and using smaller time steps, but this doesn't work either. Here are all my config files. BlockMeshDict Code:
*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 8 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Radio 4; MinRadio #calc "-1.0*$Radio"; RadioEntr 2; MinRadioEntr #calc "-1.0*$RadioEntr"; RadioSal 2; MinRadioSal #calc "-1.0*$RadioSal"; EspPlaca 1; DistEntr 8; DistPlacaSal #calc "$DistEntr + $EspPlaca"; DistSalida #calc "$DistPlacaSal +8"; halfAngle 45.0; midPointRadio #calc "$Radio*sin(degToRad($halfAngle))"; MinmidPointRadio #calc "-1.0*$midPointRadio"; midPointRadioEntr #calc "$RadioEntr*sin(degToRad($halfAngle))"; MinmidPointRadioEntr #calc "-1.0*$midPointRadioEntr"; midPointRadioSal #calc "$RadioSal*sin(degToRad($halfAngle))"; MinmidPointRadioSal #calc "-1.0*$midPointRadioSal"; RadialMeshing 30; LongMeshing 50; vertices ( (0 0 0) //0 (0 $Radio 0) //1 ($MinRadio 0 0) //2 (0 $MinRadio 0) //3 ($Radio 0 0) //4 (0 $Radio $DistEntr) //5 ($MinRadio 0 $DistEntr) //6 (0 $MinRadio $DistEntr) //7 ($Radio 0 $DistEntr) //8 (0 $RadioEntr $DistEntr) //9 ($MinRadioEntr 0 $DistEntr) //10 (0 $MinRadioEntr $DistEntr) //11 ($RadioEntr 0 $DistEntr) //12 (0 $RadioSal $DistPlacaSal) //13 ($MinRadioSal 0 $DistPlacaSal) //14 (0 $MinRadioSal $DistPlacaSal) //15 ($RadioSal 0 $DistPlacaSal) //16 (0 $Radio $DistPlacaSal) //17 ($MinRadio 0 $DistPlacaSal) //18 (0 $MinRadio $DistPlacaSal) //19 ($Radio 0 $DistPlacaSal) //20 (0 $Radio $DistSalida) //21 ($MinRadio 0 $DistSalida) //22 (0 $MinRadio $DistSalida) //23 ($Radio 0 $DistSalida) //24 (0 $RadioEntr 0) //25 ($MinRadioEntr 0 0) //26 (0 $MinRadioEntr 0) //27 ($RadioEntr 0 0) //28 (0 $RadioSal $DistSalida) //29 ($MinRadioSal 0 $DistSalida) //30 (0 $MinRadioSal $DistSalida) //31 ($RadioSal 0 $DistSalida) //32 ); blocks ( hex (28 4 1 25 12 8 5 9) ($RadialMeshing $RadialMeshing $LongMeshing) simpleGrading (1 1 0.5) hex (2 26 25 1 6 10 9 5) ($RadialMeshing $RadialMeshing $LongMeshing) simpleGrading (1 1 0.5) hex (26 2 3 27 10 6 7 11) ($RadialMeshing $RadialMeshing $LongMeshing) simpleGrading (1 1 0.5) hex (4 28 27 3 8 12 11 7) ($RadialMeshing $RadialMeshing $LongMeshing) simpleGrading (1 1 0.5) hex (25 26 27 28 9 10 11 12) ($RadialMeshing $RadialMeshing $LongMeshing) simpleGrading (1 1 0.5) hex (9 10 11 12 13 14 15 16) ($RadialMeshing $RadialMeshing 50) simpleGrading (1 1 1) hex (16 20 17 13 32 24 21 29) ($RadialMeshing $RadialMeshing $LongMeshing) simpleGrading (1 1 0.5) hex (13 17 18 14 29 21 22 30) ($RadialMeshing $RadialMeshing $LongMeshing) simpleGrading (1 1 0.5) hex (14 18 19 15 30 22 23 31) ($RadialMeshing $RadialMeshing $LongMeshing) simpleGrading (1 1 0.5) hex (15 19 20 16 31 23 24 32) ($RadialMeshing $RadialMeshing $LongMeshing) simpleGrading (1 1 0.5) hex (13 14 15 16 29 30 31 32) ($RadialMeshing $RadialMeshing $LongMeshing) simpleGrading (1 1 0.5) ); edges ( arc 1 2 ($MinmidPointRadio $midPointRadio 0) arc 2 3 ($MinmidPointRadio $MinmidPointRadio 0) arc 3 4 ($midPointRadio $MinmidPointRadio 0) arc 4 1 ($midPointRadio $midPointRadio 0) arc 5 6 ($MinmidPointRadio $midPointRadio $DistEntr) arc 6 7 ($MinmidPointRadio $MinmidPointRadio $DistEntr) arc 7 8 ($midPointRadio $MinmidPointRadio $DistEntr) arc 8 5 ($midPointRadio $midPointRadio $DistEntr) arc 9 10 ($MinmidPointRadioEntr $midPointRadioEntr $DistEntr) arc 10 11 ($MinmidPointRadioEntr $MinmidPointRadioEntr $DistEntr) arc 11 12 ($midPointRadioEntr $MinmidPointRadioEntr $DistEntr) arc 12 9 ($midPointRadioEntr $midPointRadioEntr $DistEntr) arc 13 14 ($MinmidPointRadioSal $midPointRadioSal $DistPlacaSal) arc 14 15 ($MinmidPointRadioSal $MinmidPointRadioSal $DistPlacaSal) arc 15 16 ($midPointRadioSal $MinmidPointRadioSal $DistPlacaSal) arc 16 13 ($midPointRadioSal $midPointRadioSal $DistPlacaSal) arc 17 18 ($MinmidPointRadio $midPointRadio $DistPlacaSal) arc 18 19 ($MinmidPointRadio $MinmidPointRadio $DistPlacaSal) arc 19 20 ($midPointRadio $MinmidPointRadio $DistPlacaSal) arc 20 17 ($midPointRadio $midPointRadio $DistPlacaSal) arc 21 22 ($MinmidPointRadio $midPointRadio $DistSalida) arc 22 23 ($MinmidPointRadio $MinmidPointRadio $DistSalida) arc 23 24 ($midPointRadio $MinmidPointRadio $DistSalida) arc 24 21 ($midPointRadio $midPointRadio $DistSalida) arc 25 26 ($MinmidPointRadioEntr $midPointRadioEntr 0) arc 26 27 ($MinmidPointRadioEntr $MinmidPointRadioEntr 0) arc 27 28 ($midPointRadioEntr $MinmidPointRadioEntr 0) arc 28 25 ($midPointRadioEntr $midPointRadioEntr 0) arc 29 30 ($MinmidPointRadioSal $midPointRadioSal $DistSalida) arc 30 31 ($MinmidPointRadioSal $MinmidPointRadioSal $DistSalida) arc 31 32 ($midPointRadioSal $MinmidPointRadioSal $DistSalida) arc 32 29 ($midPointRadioSal $midPointRadioSal $DistSalida) ); patches ( wall fixedWalls ( (1 5 8 4) (4 8 7 3) (7 3 2 6) (2 6 1 5) (9 13 16 12) (12 16 15 11) (11 15 10 14) (10 14 9 13) (17 21 20 24) (20 24 19 23) (19 23 18 22) (18 22 17 21) (5 9 10 6) (10 6 7 11) (11 7 12 8) (8 12 5 9) (17 13 14 18) (17 20 16 13) (20 19 15 16) (14 15 19 18) ) patch inlet ( (1 2 26 25) (2 3 27 26) (3 4 28 27) (4 1 25 28) (25 26 27 28) ) patch Outlet ( (29 30 31 32) (21 22 30 29) (22 23 31 30) (23 24 32 31) (24 21 29 32) ) ); mergePatchPairs ( ); // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 8 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object controlDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // application icoFoam; startFrom startTime; startTime 0; stopAt endTime; endTime 20; deltaT 0.001; writeControl runTime; writeInterval 1; purgeWrite 0; writeFormat ascii; writePrecision 12; writeCompression off; timeFormat general; timePrecision 6; runTimeModifiable yes; // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 8 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvSchemes; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // ddtSchemes { default CrankNicolson 0.5; } gradSchemes { default Gauss linear; grad(p) Gauss linear; } divSchemes { default none; div(phi,U) Gauss linearUpwind grad(U); } laplacianSchemes { default Gauss linear orthogonal; } interpolationSchemes { default linear; } snGradSchemes { default orthogonal; } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 8 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvSolution; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // solvers { p { solver PCG; preconditioner DIC; tolerance 1e-05; relTol 1e-02; maxIter 10000; } pFinal { $p; relTol 1e-03; } U { solver smoothSolver; smoother symGaussSeidel; tolerance 1e-05; relTol 1e-02; maxIter 10000; } } PISO { nCorrectors 3; nNonOrthogonalCorrectors 0; } relaxationFactors { fields { ".*" 0.3; } equations { ".*" 0.3; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 8 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volVectorField; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0.1); boundaryField { inlet { type fixedValue; value uniform (0 0 0.1); } Outlet { type zeroGradient; } fixedWalls { type fixedValue; value uniform (0 0 0); } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 8 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; object p; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -2 0 0 0 0]; internalField uniform 0; boundaryField { inlet { type zeroGradient; } Outlet { //I have also tried using pRefCell 0, pRefValue 0 and zeroGradient in this condition type fixedValue; value uniform 0; } fixedWalls { type zeroGradient; } } // ************************************************************************* // |
Continuous casting simulation problem | luke.christ | FLUENT | 6 | November 24, 2020 08:14 |
Defrosting Windscreen Simulation diverges and leads to floating point exception | Dehyp | STAR-CCM+ | 9 | March 7, 2017 11:27 |
Problem storing values at UDM for tranisient dynamic mesh simulation | xab | Fluent UDF and Scheme Programming | 4 | December 22, 2016 05:10 |
Problem in initializing transient simulation with a finer mesh | sidd | CFX | 8 | April 29, 2016 03:25 |
Dynamic mesh simulation (pimpleDyMFoam) problem | sidlof | OpenFOAM Running, Solving & CFD | 6 | April 12, 2013 12:24 |
