Simulating simple shear flow in OpenFOAM
Old   March 4, 2021, 07:49
Default Simulating simple shear flow in OpenFOAM
Shibi is on a distinguished road
Hello to all,
I am trying to simulate a 2D simple shear flow case with OpenFOAM using simpleFOAM. Afterwards, I would like to use the steady-state velocity field in some pimpleFoam simulations.
I am having a problem with simpleFoam. I get complete convergence of the x-component of velocity, however, I cannot converge the pressure and the z-component. I have run out of ideas, and would appreciate some help!
The dictionaries I am using are:
convertToMeters 0.1;
vertices
    (0 0 0)
    (1 0 0)
    (1 0.25 0)
    (0 0.25 0)
    (0 0 0.25)
    (1 0 0.25)
    (1 0.25 0.25)
    (0 0.25 0.25)
blocks
    hex (0 1 2 3 4 5 6 7) (40 10 10) simpleGrading (1 1 1)
edges
boundary
    top
        type patch;
        faces
            (4 5 6 7)
    bottom
        type patch;
        faces
           (0 3 2 1)
    wall1
        type cyclic;
        neighbourPatch wall2;
        faces
             (2 6 5 1)
    wall2
        type cyclic;
        neighbourPatch wall1;
        faces
            (0 4 7 3)
    emptyFaces
        type empty;
        faces
           (1 5 4 0)
            (3 7 6 2)
mergePatchPairs
|  \\    /   O peration     | Version:  v2012                                 |
|   \\  /    A nd           | Website:  www.openfoam.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    location    "0";
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    top
        type            fixedValue;
        value           uniform (1 0 0);
    bottom
        type            fixedValue;
        value           uniform (0 0 0);
    "(wall.*)"
       type                      cyclic;
   emptyFaces
        type            empty;
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    object      p;
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform 0;
boundaryField
        type    zeroGradient;
    "(wall.*)"
       type     cyclic;
    emptyFaces
        type            empty;
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      fvSchemes;
ddtSchemes
    default         steadyState;
gradSchemes
    default         Gauss linear;
divSchemes
    default         none;
    div(phi,U)      Gauss linear;
    div((nuEff*dev2(T(grad(U))))) Gauss linear;
laplacianSchemes
    default         Gauss linear uncorrected;
interpolationSchemes
    default         linear;
snGradSchemes
    default         uncorrected;
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      fvSolution;
solvers
    p
        /*solver          GAMG;
        smoother        DIC;
        tolerance       1e-6;
        relTol          0.01;*/
        solver          PCG;
        preconditioner  DIC;
        tolerance       1e-06;
        relTol          0.1;
    "(U|sigma)"
        /*solver          smoothSolver;
        smoother        symGaussSeidel;
        tolerance       1e-6;
        relTol          0.1;*/
        solver          PBiCG;
        preconditioner  DILU;
        tolerance       1e-06;
        relTol          0.1;
    pFinal
        $p;
        relTol          0;
    "(U|sigma)Final"
        $U;
        relTol          0;
SIMPLE
    nNonOrthogonalCorrectors 0;
    pRefCell 0;
    pRefValue 0;
    residualControl
        p               1e-6;
        U                1e-6;
relaxationFactors
    fields
        p   0.3;
    equations
        U   0.7;
Shibi is offline   Reply With Quote
Old   March 5, 2021, 08:50
JuanMi
keitaro7_14 is on a distinguished road
Try to fix the value of the pressure in a cell or in a whole patch of a boundary.
Like here:
https://github.com/OpenFOAM/OpenFOAM...pipeCyclic/0/p
keitaro7_14 is offline   Reply With Quote
Old   March 8, 2021, 06:00
Like here:
Thank you for the reply. However, this is already being made in the Simple subdict with the parameters
pRefCell 0;
pRefValue 0;
I can get it to converge it I put a very small value for pRefValue, e.g., 0.1. However I do not understand why...
simple shear, simplefoam convergence
Buoyant environmental flow including salinity in OpenFOAM Jost K OpenFOAM Programming & Development 18 September 4, 2020 05:44
OpenFOAM course for beginners Jibran OpenFOAM Announcements from Other Sources 2 November 4, 2019 09:51
OpenFOAM Training Jan-Jul 2017, Virtual, London, Houston, Berlin CFDFoundation OpenFOAM Announcements from Other Sources 0 January 4, 2017 07:15
OpenFOAM v3.0+ ?? SBusch OpenFOAM 22 December 26, 2016 15:24
Open channel flow with icoFoam solver in openFoam yash lakhani Main CFD Forum 0 May 23, 2016 09:03
