Treatment of unimportant walls in turbulent simulations
Old   February 25, 2021, 06:05
Default Treatment of unimportant walls in turbulent simulations
Gerhard
Gerhard is on a distinguished road
Good day,
In a situation where you have walls where the near-wall flow is of importance and other walls where the near-wall flow is not important, how should you treat the unimportant walls?
Here is an example: Flow enters a large plenum chamber, then flows through a fan, and finally discharges to the atmosphere through a diffuser.
Not wanting to waste cells at the plenum walls (which are not that important), the y+ values there might be in excess of 1000.
Since the near-wall flow in the vicinity of the fan and especially in the diffuser is important, more cells will be used to achieve 30 < y+ < 100 for wall-functions, or even y+~1 if integration through the sub-layer is desired.
The question: what should the boundary conditions of the unimportant walls be where the y+-values are, let's say y+ > 500?
These are my thoughts for the k-omega turbulence model using a wall-function approach:
Option 1
U
Important -> noSlip
Unimportant -> slip
k
Important -> kqRWallFunction
Unimportant -> zeroGradient
omega
Important -> omegaWallFunction
Option 2
U
Important -> noSlip
Unimportant -> noSlip
k
Unimportant -> fixedValue of 1e-10
omega
Unimportant -> fixedValue of 1e10
Any suggestions?
Thanks.
Gerhard is offline   Reply With Quote
Old   February 27, 2021, 09:42
Gerhard
If I may reply to my own question...
This is my thinking. Please tell me if you do not agree.
Whether you treat these "unimportant" walls using either Option 1 or 2 (provided in the previous post), it should not influence the key results.
However, if Option 1 and 2 do not yield similar key results, then these walls are in fact not "unimportant".
In other words, they are important, and if that is the case, one should aim to achieve 30 < y+ < 100 if you which to model the near wall flow using wall-functions.
Old   March 1, 2021, 03:43
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
Hi Gerhard,
a tricky topic. In my personal optinion, I would stick with option 3.
  • A wall is treated as a wall so -> noSlip
  • As we have a wall there, I would use wall functions even if y+ >> 100
  • The important thing is that the first cell center is not in the viscouse sub-layer ( y+ > 17 -> Reference to Ferziger & Peric if I do have the number correclty in my head)
However, I believe that every guy who works in the turbulence field will tell us that all approaches are wrong
Keep foaming,
Tobias Holzmann
Tobi is offline   Reply With Quote
Old   March 1, 2021, 04:02
Gerhard
Hi Tobi,
Haha, I like your remark about the turbulence guys
I agree with what you say about using noSlip for walls.
Using wall functions for like y+ ~ 1000 just feels strange: You are then in the defect layer and wall functions are not designed to describe the flow that far away from the wall... But what else, right?
And as I mentioned earlier that you should probably just aim to have 30 < y+ < 100, it can really be a huge challenge when you are working with big systems of relatively complex geometry. Getting quality layers near the wall can then really be a pain and time consuming.
Thanks for your inputs. I appreciate it.
Regards,
Gerhard
noslip condition, slip condition, turbulence quantities, wall boundary conditions
Treatment of rough walls with SST turbulence model R4z0rX CFX 5 November 27, 2019 17:02
[ICEM] Shadow walls in Fluent. ICEM meshes vs Workbench aarvay ANSYS Meshing & Geometry 11 January 12, 2017 13:51
Natural convection - Inlet boundary condition max91 CFX 1 July 29, 2008 21:28
Turbulent flow at walls in complex flows Bo Jensen Main CFD Forum 2 March 23, 2000 23:42
turbulent mixing of two fluids ulrich bieder Main CFD Forum 2 October 9, 1999 17:15
