Add source term to KEpsilon model in given location
Old   February 24, 2021, 11:37
Default Add source term to KEpsilon model in given location
Kabir Shariff
Kbshariff is on a distinguished road
Hello foamers,
I am simulating tidal turbine using actuator disc concept in OpenFOAM v2006.
I want to add a source term of turbulence production term around the disc region only.
How can I specify the location where the source term is added???
Thanks
Kbshariff is offline   Reply With Quote
Old   February 24, 2021, 15:15
Michael Alletto
mAlletto will become famous soon enough
You can use a codedfvOption an include the source term in the k equation. Take a look at the actuator disk model how to specify the locations https://develop.openfoam.com/Develop...tionDiskSource
Best
Michael
mAlletto is offline   Reply With Quote
Old   March 8, 2021, 04:27
Kabir Shariff
Best
Michael
Hello Michael,
I use the coded fvoptions as suggested and I got this error. First of all, I had to compile the coded fv options ( I am using a cluster server v2006)
below is my fv options file. I am interested in adding the following term (see attachment please)
codedSource
    type            scalarCodedSource;
    selectionMode   cellSet;
    cellSet         sourceDisk1;
    fields          (epsilon);
    name            codedSource;
    codeAddSup
        const Time& time = mesh().time();
        const scalarField& V = mesh_.V();
 	const scalarField& rh 	= 1000;
	const scalarField& eps = 0.06287;
	const scalarField& kk	= 1.215;
	const scalarField& Cm2	= 0.09;
	const scalarField & epsilonSource = eqn.source();
	forAll(C,i)
		epsilonSource[i] += rh*Cm2*pow(eps,2)/kk*V[i];
             Pout << "***codeAddSup***" << endl;
    codeCorrect
    codeConstrain
    sourceTimeCoeffs
        // Dummy entry
and here is the log file for the error message
smoothSolver:  Solving for Ux, Initial residual = 1, Final residual = 0.0496559290788, No Iterations 4
smoothSolver:  Solving for Uy, Initial residual = 0.999999999508, Final residual = 0.0927538575586, No Iterations 3
smoothSolver:  Solving for Uz, Initial residual = 0.999999999943, Final residual = 0.0388575837312, No Iterations 3
[125] swak4Foam: Allocating new repository for sampledGlobalVariables
GAMG:  Solving for p, Initial residual = 1, Final residual = 0.000945134305598, No Iterations 28
time step continuity errors : sum local = 4.29755393053e-06, global = -5.81621224202e-09, cumulative = -5.81621224202e-09
Using dynamicCode for fvOption::codedSource at line 52 in "/dlocal/run/8137670/constant/fvOptions.codedSource"
Could not load "/dlocal/run/8137670/dynamicCode/platforms/linux64GccDPInt32Opt/lib/libcodedSource_80756ad56d8baed425ef1007b62ccf592e79c6c3.so"
/dlocal/run/8137670/dynamicCode/platforms/linux64GccDPInt32Opt/lib/libcodedSource_80756ad56d8baed425ef1007b62ccf592e79c6c3.so: cannot open shared object file: No such file or directory
Invoking wmake libso /dlocal/run/8137670/dynamicCode/codedSource
    ln: ./lnInclude
    dep: codedFvOptionTemplate.C
    Ctoo: codedFvOptionTemplate.C
/dlocal/run/8137670/constant/fvOptions.codedSource: In member function ‘virtual void Foam::fv::codedSourceFvOptionscalarSource::addSup(Foam::fvMatrix<double>&, Foam::label)’:
/dlocal/run/8137670/constant/fvOptions.codedSource:102:17: error: aggregate ‘std::ofstream file’ has incomplete type and cannot be defined
/dlocal/run/8137670/constant/fvOptions.codedSource:103:33: error: incomplete type ‘std::ofstream {aka std::basic_ofstream<char>}’ used in nested name specifier
/dlocal/run/8137670/constant/fvOptions.codedSource:103:54: error: incomplete type ‘std::ofstream {aka std::basic_ofstream<char>}’ used in nested name specifier
/dlocal/run/8137670/constant/fvOptions.codedSource: In member function ‘virtual void Foam::fv::codedSourceFvOptionscalarSource::addSup(const volScalarField&, Foam::fvMatrix<double>&, Foam::label)’:
make: *** [Make/linux64GccDPInt32Opt/codedFvOptionTemplate.o] Error 1
[0]
[0]
[0] --> FOAM FATAL IO ERROR:
[0] Failed wmake "dynamicCode/codedSource/platforms/linux64GccDPInt32Opt/lib/libcodedSource_80756ad56d8baed425ef1007b62ccf592e79c6c3.so"
[0]
[0]
[0] file: /dlocal/run/8137670/constant/fvOptions.codedSource at line 52.
[0]
[0]     From void Foam::codedBase::createLibrary(Foam::dynamicCode&, const Foam::dynamicCodeContext&) const
[0]     in file db/dynamicLibrary/codedBase/codedBase.C at line 237.
[0]
FOAM parallel run exiting
[0]
application called MPI_Abort(MPI_COMM_WORLD, 1) - process 0
In: PMI_Abort(1, application called MPI_Abort(MPI_COMM_WORLD, 1) - process 0)
srun: Job step aborted: Waiting up to 32 seconds for job step to finish.
slurmstepd: error: *** STEP 8137670.2 ON my253 CANCELLED AT 2021-03-08T09:09:52 ***
srun: error: my261: tasks 112-139: Killed
srun: Terminating job step 8137670.2
srun: error: my253: tasks 0-27: Killed
srun: error: my254: tasks 28-55: Killed
srun: error: my260: tasks 84-111: Killed
srun: error: my259: tasks 56-83: Killed
Thank you
Old   March 8, 2021, 04:58
Michael Alletto
Seems a problem with the output. Can you comment the Pout line.
In the error the appear some line numbers. Which line number are this?
Old   March 8, 2021, 05:14
Kabir Shariff
1./ I have commented the Pout line, but I still have the same problem
2/ The line numbers are for the parallel processors, I am running the simulation on cluster network.
Old   March 8, 2021, 05:20
Michael Alletto
scalar rh 	= 1000; scalar eps = 0.06287; scalar kk	= 1.215; scalar Cm2	= 0.09;
you're assign scalarField to scalars ... but you treat it as scalar inside the for loop
Old   March 8, 2021, 06:42
Kabir Shariff
I want to apply the source term to only cells defined in the cellset, not the entire domain
I have specified the cellset using topoSet
Old   March 8, 2021, 07:39
Michael Alletto
forAll(C,i)     {         epsilonSource[i] += rh*Cm2*pow(eps,2)/kk*V[i];     }
in your code rh, Cmu, eps and kk are scalarFileds ...
you do not define the size either ...
this may be your mistake
Old   March 8, 2021, 09:58
Kabir Shariff
thank you for the observation
I found another method to apply scalar fields using the semi-implicit fvOptions below
scalarSource
    type            scalarSemiImplicitSource;
    volumeMode      absolute;
    injectionRateSuSp
        k           (30.7 0);
        epsilon     (1.5  0);
Is it correct to calculate the value as given in the formula and add it as explicit term in the relation?
generalSource
    type            <type>SemiImplicitSource;
    volumeMode      absolute; // absolute | specific
    injectionRateSuSp
        <field>           (<explicit value> <implicit coefficient>);
thanks
Old   March 8, 2021, 10:30
Michael Alletto
No experience about your function objects. Is there no documentation
actuationdisksource, kepsilonmodel
[OpenFOAM.com] swak4foam compiling issues on a cluster saj216 OpenFOAM Installation 5 January 17, 2023 17:05
How to add Source term (2) for PYROLYSIS - reactingOneDim Kummi OpenFOAM 10 April 12, 2021 22:11
Trouble compiling utilities using source-built OpenFOAM Artur OpenFOAM Programming & Development 14 October 29, 2013 11:59
friction forces icoFoam ofslcm OpenFOAM 3 April 7, 2012 11:57
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 02:24
