February 23, 2021, 15:46 |
foam-extend 4.1 GGI check
Andrea
Rep Power: 9 |
Hello Folks
I'm working with foam-extend simulating a Francis turbine and I have problems to get a solution. In the CAD the surfaces composing the interfaces perfectly match each other. After meshed (discretization error) the differences between areas at the interfaces are: Spiral-GuideVanes: Diff = -1.54116647556601e-05 Bulb-DraftTube: Diff = 2.25976241261805e-05 According to your experience, is it enough an area difference of O(e-05) for GGI (or mixing plane) interfaces? Bests |
February 24, 2021, 06:20 |
Hrvoje Jasak
Rep Power: 33 |
This should not be a problem - compare the error in area between the two surfaces with respect to the flux error.
Can you post the whole message?
Hrvoje Jasak Providing commercial FOAM/OpenFOAM and CFD Consulting: http://wikki.co.uk |
February 24, 2021, 06:35 |
Andrea
Rep Power: 9 |
Thank you for reply Prof. Jasak.
The message is the following: GGI pair (SP-GV, GV-SP) Area: 0.254671269026831 0.254686680691586 Diff = -1.54116647556601e-05 or 0.00605122525991961 % Flux: 0.949992608907554 0.950088338717345 Diff = -9.57298097908899e-05 or 0.010075885145599 % GGI pair (BULB-DT, DT-BULB) Area: 0.138815526804067 0.138792929179941 Diff = 2.25976241261805e-05 or 0.0162788879936147 % Flux: 0.972494692318502 0.972510217271029 Diff = -1.55249525264356e-05 or 0.0015963793748101 % Regarding the last interface (mixing-plane) the mixing plane check is not working in parallel (this can be verified also running the tutorial "axialTurbine_mixingPlane"). I made the grids using Numeca AG5 and Omnis. The checkMesh looks fine. Create time Create polyMesh for time = 0 Initializing the GGI interpolator between master/shadow patches: SP-GV/GV-SP Initializing the GGI interpolator between master/shadow patches: BULB-DT/DT-BULB Time = 0 Mesh stats all points: 22230489 live points: 13966149 all faces: 46481093 live faces: 38339883 internal faces: 35820020 cells: 12196229 boundary patches: 27 point zones: 0 face zones: 6 cell zones: 4 Overall number of cells of each type: hexahedra: 11986443 prisms: 0 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 0 polyhedra: 209786 Checking topology... Boundary definition OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. *Number of regions: 4 The mesh has multiple regions which are not connected by any face. <<Writing region information to "0/cellToRegion" Nuumber of cells per region: 0 330992 1 0 2 0 3 0 Checking geometry... This is a 3-D mesh Overall domain bounding box (-0.7879466659 -1.671217118 -0.2864486732) (0.8220821991 4.442373826 3.74207617) Mesh (non-empty, non-wedge) directions (1 1 1) Mesh (non-empty) directions (1 1 1) Mesh (non-empty, non-wedge) dimensions 3 Boundary openness (-7.36175726854743e-13 -2.65983934844024e-12 2.58673887309245e-12) Threshold = 1e-06 OK. Max cell openness = 5.15135387404077e-08 OK. Max aspect ratio = 267.233167283032 OK. Minumum face area = 3.35187928762322e-09. Maximum face area = 0.011201607594839. Face area magnitudes OK. Min volume = 3.13556677637343e-12. Max volume = 0.00116740721267175. Total volume = 3.08841375862224. Cell volumes OK. Mesh non-orthogonality Max: 72.648044449205 average: 18.5441847118136 Threshold = 70 *Number of severely non-orthogonal faces: 22. Non-orthogonality check OK. Writing 22 non-orthogonal faces to set nonOrthoFaces Face pyramids OK. Max skewness = 2.77047715280581 OK. Mesh OK. End |
August 22, 2022, 12:01 |
Jianfeng
Rep Power: 5 |
Hi, did you use the ggi interface in parallel mode ? I find the initialization takes too much time when I use ggi interface in parallel? Do I need to decompose the mesh in another way ? Thanks!
foam-extend 4.1, ggi, interfaces, mixing-plane |
Block coupling three equations using foam extend 4.1 | ELwardi | OpenFOAM Programming & Development | 2 | March 19, 2019 11:35 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 15:11 |
Problems in compiling paraview in Suse 10.3 platform | chiven | OpenFOAM Installation | 3 | December 1, 2009 08:21 |
Problem with rhoSimpleFoam | matteo_gautero | OpenFOAM Running, Solving & CFD | 0 | February 28, 2008 07:51 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 09:19 |
