Velocity profile in pipe is not parabolic, chtMultiRegionFoam
Old   February 22, 2021, 06:46
Default Velocity profile in pipe is not parabolic, chtMultiRegionFoam
JeffFoam is on a distinguished road
Hey everyone,
I'm trying to simulate turbulent, internal flow and conjugate heat transfer using chtMultiRegionFoam. As a test case, I'm using a straight pipe with L = 0,5 m, r1 = 0,005 m and r2=0,01 m, materials copper and water. Everything seems to work well, except for the velocity profile that results. It should be shaped like a parabola, but instead it shows a 'flat m'.
I've attached both the result (solved with chtMultiRegionFoam) and what it should look like (solved with simpleFoam). fvSchemes and fvSolutions of the fluid region are also attached.
All boundary conditions in the 0 folder are the same for the relevant files in both cases. momentumTransport in both cases is RAS with kOmegaSST. I'm using OpenFOAM.org v8.
Could anyone tell me what I need to do in order to get the parabolic flow profile in my chtMultiRegionFoam case?
JeffFoam is offline   Reply With Quote
Old   February 22, 2021, 16:02
rightnow's Avatar
Andrey
rightnow is on a distinguished road
Hello, JeffFoam.
1. Parabolic profile is formed only in laminar flow (Re < 2300 ). The law 1/7 is correct for turbulent flow.
2. I think your chtMultiRegionFoam case didn't converged. Try to increase timesteps number and attach residuals plot.
rightnow is offline   Reply With Quote
velocity profile mixing hot and cold water in a pipe ari92 OpenFOAM 1 June 1, 2017 16:11
Parabolic velocity profile Booundary condition Guenda OpenFOAM Pre-Processing 18 November 21, 2016 06:20
3D Pipe Flow Problem: Velocity profile is not symmetric malicemethods FLUENT 0 May 27, 2015 12:51
[swak4Foam] problem with a parabolic velocity profile Claudio87 OpenFOAM Community Contributions 5 May 29, 2014 10:30
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
