Can i replace a fan with constant velocity or pressure gradient?
Old   February 17, 2021, 07:17
Default Can i replace a fan with constant velocity or pressure gradient?
Saurav Kumar
srv537 is on a distinguished road
I am working on a project of heat transfer. I have a heat source and fan blowing on it. can i simplify this problem and replace fan with a constant velocity inlet or Pressure gradient based on the flow coefficient or pressure coefficient?
if not then what should i do in openfoam?
srv537 is offline   Reply With Quote
UDF for zero pressure gradient at BC outlet ghordog Fluent UDF and Scheme Programming 1 April 28, 2022 06:12
Wind tunnel Boundary Conditions in Fluent metmet FLUENT 6 October 30, 2019 13:23
Same pressure gradient but different velocity field TurbJet Main CFD Forum 22 April 28, 2018 04:35
Pressure loss Velocity coupling CFXMUFFIN CFX 1 February 6, 2016 05:43
vortex cause pressure gradient or pressure gradient induce vortex? fruitkiwi Main CFD Forum 4 June 12, 2012 02:12
