Unrealistic jet phenomenon in twoPhaseEulerFoam |
February 16, 2021, 21:15 |
Huan Zhang
Rep Power: 6 |
Dear all,
I am recently struggling with the air jet into stagnant water, as you can see in the attachment, the air phase trajectory divided from the jet centerline, which is not realistic. I am using twoPhaseEulerFoam, the lift force coefficient is set to be 0.5 (I saw many literature using this value). Is there anybody facing the same problem or can you give me a suggestion? Very appreciate. |
February 16, 2021, 21:41 |
Katsantonis Michalis
Rep Power: 9 |
Not sure if it will help, but check this paper:
HTML Code:
https://www.sciencedirect.com/science/article/pii/S2210983815001364 |
February 16, 2021, 22:11 |
#3 | |
Huan Zhang
Rep Power: 6 |
Thanks for the paper, I checked the paper but the setup is more or less the same, I used the fvScheme and fvSolution from the bubble column tutorial. I think the main reason is the lift force. In this paper, Tomiyama lift coefficient is used, but when I use the same coefficient, the result is similar. I have also tried Cl=0.1, the result seems better, but the lateral distribution is thinner than realistic (left figure). Furthermore, I tried the classic Deen Column using mixture rans model, the distribution is also unrealistic, as you can see in the right figure at 10 s. The lift coefficient is 0.25 in this case. Do you have any suggestion about this phenomenon? |
July 1, 2022, 16:42 |
Huan Zhang
Rep Power: 6 |
This problem has not been solved yet, looking forward to any suggestions1
"Hand" calculation jet fan in the garage | mageno | Main CFD Forum | 3 | August 7, 2021 20:09 |
twoPhaseEulerFoam confined plunging jet simulation failed | ves | OpenFOAM Running, Solving & CFD | 2 | June 17, 2020 06:08 |
2D Plane Jet Fluent Solution | doug | Main CFD Forum | 11 | February 4, 2019 10:34 |
Unrealistic behavior in twoPhaseEulerFoam | voingiappone | OpenFOAM Running, Solving & CFD | 7 | December 5, 2014 17:33 |
Jet in Supersonic Crossflow, controlling mass flow rate | ChrisA | OpenFOAM Running, Solving & CFD | 3 | November 13, 2012 19:20 |
