adding heat flux to fvOptions
Old   February 16, 2021, 07:09
Post adding heat flux to fvOptions
george
scfd is on a distinguished road
I've a heat transfer case between solid and fluid region.
I'm using
compressible::turbulentTemperatureCoupledBaffleMixed;
boundary condition both of solid_to_fluid and fluid_to_solid. I want to add heat flux to solid region.
I searched with this command
chtMultiRegionFoam -listFvOptions
and I looked their source code but I didn't find anything about heat flux.
Also when I try to do this with externalWallHeatFluxTemperature boundary condition, I get this error
Patch field for T on fluid_to_solid is of type compressible::turbulentTemperatureCoupledBaffleMixed
The neighbouring patch field T on solid_to_fluid is required to be the same, but is currently of type externalWallHeatFluxTemperature
and it doesn't make sense to define the heat flux into the fluid region.
Is there a way adding heat flux (W/m2) to solid region with fvOptions?
Best regard
scfd is offline   Reply With Quote
chtmultiregionfoam, heat flux, heat transfer
Measure of Heat Flux on a surface MathieuCrslt FLUENT 0 October 10, 2018 06:58
How do you use heat flux as a boundary condition in a non-wall area in UDF? JuBong Fluent UDF and Scheme Programming 2 July 2, 2018 22:15
Doubt - Variable Heat Flux input - UDF Neethu_N FLUENT 1 December 19, 2017 12:48
conjugateHeatFoam + interFoam farhagim OpenFOAM Programming & Development 15 July 19, 2016 08:55
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
