error at the running FSI with OpenFOAM and Calculix adapted with preCICE |
February 13, 2021, 02:36 |
Hito
Hi Foamer,
I am just running the case by the FSI with OpenFOAM-v2012 and Calculix adapted with preCICE, I checked the running well the tutorial case, but I modified to my simulation case, when I used the -parallel run, I got the error like attached(Fluid.log), but in the case when I ran the case with non-parallel, it does go through, keep running. The error message said that it seems due to the RBF mapping from mesh solid to mesh Fluid-Mesh-Nodes, so in order to follow to that, I modified in the "precice-config.xml", at the mapping I switched to the "nearest-neighbor" or "nearest-projection" from the "rbf-thin-plate-splines" , but same error wet out. Does anyone have any solution or advise to that error ? Beforehand, Many thanks ! I attached "Fluid.log", "solid.log", "Fluid_decomposePar.log", "Fluid_reconstructPar.log", "precice-config.xml". |
Dynamic Mesh issue when coupling OpenFOAM with FSI | ConorMD | OpenFOAM Running, Solving & CFD | 0 | May 12, 2020 07:19 |
New CastNet release: FSI-coupling with OpenFOAM and CalculiX based on preCICE | MartinB | OpenFOAM Announcements from Other Sources | 0 | April 30, 2020 07:53 |
Compilation error for OpenFoam FSI solver with third party FEA code | danny261083 | OpenFOAM Running, Solving & CFD | 1 | October 6, 2017 10:50 |
New CastNet Release: GUI Environment for OpenFOAM and CalculiX | MartinB | OpenFOAM Announcements from Other Sources | 0 | January 13, 2017 11:27 |
[Other] Openfoam output-format for calculix (FEM) - create the "cells" file in OpenFoam | gillers18 | OpenFOAM Meshing & Mesh Conversion | 4 | April 28, 2015 04:24 |
